Accessory/Custom Installer
I am looking for a reputable shop in the Northwest Ohio/Northeast Indiana/Southeast Michigan Area that can help with any or all of the items below:
My build date is 8/1/22.1FT8W3BT7NEF10334
W3B 2022 F-350 4x4 SD Crew Cab 8' box 176" WB SRW Platinum
I would like to add the following accessories. Quote the items you can install.
68 GALLON REPLACEMENT FUEL TANK FOR 2017-2022 FORD POWERSTROKE 6.7L CREW CAB LONG BED
WOLO EXPRESS PRO PLUS HORN KIT
CARGOGLIDE SKU: CG1000XL-9548
LEER 100XQ cap
Forscan Upgrades
Upgrade Shocks
Undercoat
Interior Protection
Exterior Protection
Aquapel
35% tint on moon roof, rear and side windows
LEER 100XQ cap
Forscan Upgrades
Upgrade Shocks
Undercoat
Interior Protection
Exterior Protection
Aquapel
Also, and I’m not sure if this matters to you or not but by changing your fuel tank and doing FORScan mods before the factory warranty expires, you’re taking a big chance of being denied warranty service if something goes wrong with your vehicle.
Sure, shops and other members will say I’m wrong but it’s up to you.
For instance, I had FORD install 20" OEM FORD wheels and tires and my warranty is intact. I installed a front hitch and a brush guard and my warranty should be intact. My truck was ordered with snowplow/camper pkg and as such is certified by FORD to carry that additional weight and stress.
Don't expect to receive powetrain warranty service if the PCM has been modified to defeat emissions or increase power or mileage. Don't expect to receive suspension warranty service if you have installed an aftermarket leveling or lift kit or substantially larger tires and aftermarket wheels. Use common sense and dealerships will apply the same, usually. A warranty is like a privilege, if you abuse it, you lose it. 😆
But, the forscan updates to the computer may be an issue.
