Vibration with small trailer
Old Jul 3, 2022 | 08:11 PM
Ees73's Avatar
Ees73
Anyone noticing a vibration only when small trailer with side by side on. Over 60 mph. I have a 2020 f350 dually. Doesn't seem to do it with 21000 pound fifthwheel on it?
Old Jul 3, 2022 | 08:32 PM
RedNNBlue's Avatar
RedNNBlue
With no more information than that, I would suspect the trailer is the cause of the vibration. It could be caused by anything from improper load distribution, an out of balance tire/wheel combo, bad brakes, or even a bent trailer frame. There are other potential causes, but those are the first ones that jump to mind. Good luck on your hunt for the cause.
Old Jul 3, 2022 | 08:51 PM
T. Banning's Avatar
T. Banning
If the tires are not balanced, you need to do so. I didn't realize how much of a difference it makes, until I had my 14' tandem trailer tires/wheels balanced
Old Jul 4, 2022 | 06:10 AM
Jlotze's Avatar
Jlotze
I had the same issue. Do you still have the original bias ply tires on the utility trailer? If so, replace them with radial tires. I was told you can't really balance those cheap tires they put on small utility trailers and have them stay balanced.
Old Jul 4, 2022 | 07:25 AM
DaveZX's Avatar
DaveZX
Had same experience with small trailer tires. Worse if they sit a lot.
Old Jul 4, 2022 | 07:46 AM
ejb69's Avatar
ejb69
I pull a few small trailers. For the most part I don’t even know they are behind the truck. My dad has a really light trailer that’s made just for one atv. It tows fine with a atv on it. Empty it tends to bounce a lot. I can’t even see it behind my F350 when it’s empty. I can’t feel it. But know what it does from following dad.
I do think my car trailer and boat, tow better than the smaller single axle trailers that weigh far less.
Old Jul 4, 2022 | 11:03 AM
acdii's Avatar
acdii
The Aluminum bodies are more prone to transmit vibrations through to the driver where the steel bodies tended to absorb them. A trailer I pulled with my 2014 F150 and my 2012 F350, never felt it. Pulled it with my 2018 and right around 55-60 felt it right in my butt. One wheel on my flatbed wasn't torque right and shook the truck. After taking the wheels off and swapping them left and right and tightening them properly the vibration went away. Funny that it could be felt with the F150 but the old F350, not a thing.
Old Jul 4, 2022 | 07:34 PM
traveldawg's Avatar
traveldawg
My 2018 always vibrated with small trailers. The worst was with a Tesla on a U-Haul trailer driving from Denver to Atlanta. It did it with U-Haul cargo trailers too.
I'm not convinced it was unbalanced tires. But it could have been. It always felt like a slight shudder. Finding the right speed would lessen it.
Old Jul 5, 2022 | 02:20 PM
2019er's Avatar
2019er
For dually, you might appreciate the centramatic balancers. You'll have to explain to the tire shop what they are, along with telling them not to drop your polished aluminum wells on the shiny side, and don't destroy the wheel covers in the process. Things people that do the job for a living should know, so feeling like a complete **** to have to tell them comes with the territory, but they earned it.
Old Jul 8, 2022 | 01:01 AM
Compression-Ignition's Avatar
Picture of your setup would help.
Old Jul 23, 2022 | 09:29 AM
Ees73's Avatar
Ees73
Turns out to be bent rim they couldn't balanced switched to larger rims and radial all vibrations gone.
vtfireftr
Oct 4, 2017 10:43 AM
jh225
6.7L Power Stroke Diesel
20
Sep 1, 2012 10:23 PM
TRX250R87
2004 - 2008 F150
22
Dec 14, 2006 02:23 PM
redfishjones
2004 - 2008 F150
Nov 1, 2004 05:14 PM
J. E. Ray
2004 - 2008 F150
Apr 25, 2004 07:56 AM
