Intrusion Alert
Old Jul 2, 2022 | 11:07 AM
DAVE67FD's Avatar
DAVE67FD
Intrusion Alert
So had my alarm triggered the other morning at about 4am.
My FordPass app listed as "Alarm Triggered" and has detected vehicle intrusion and triggered the alarm.
No sign's of any issues and i live in the country.
This is the second time this has happened and first time was about 2 months ago.
Anyone experiencing random triggers and what does it take to actually trigger the intrusion alert aside from someone actually breaking glass and manually unlocking it?
Old Jul 2, 2022 | 11:17 AM
GABAR's Avatar
GABAR
Are your interior sensors turned on?
More than likely there’s a bug or insect flying around inside and the interior sensor picked up the movement.
Old Jul 2, 2022 | 11:18 AM
helifixer's Avatar
helifixer
fly or moth,
Old Jul 2, 2022 | 11:26 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There should be a big warning label on the screen every time you shut the truck off, not just a message asking if you want the interior sensors on or not.
I just turned my interior sensors off permanently.
Old Jul 2, 2022 | 02:22 PM
helifixer's Avatar
helifixer
how ?
Old Jul 2, 2022 | 03:08 PM
RowDona's Avatar
RowDona
7th Gear
Alarm
Same thing happened on mine at 03:00, defiantly makes you jump out of bed. It wasn't a bug like others are claiming, it was well below zero at the time. Turned out to be a glitch in the alarm system and ford is well aware.
Old Jul 2, 2022 | 03:12 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Originally Posted by helifixer
how ?
It's in the settings menu in the gauge cluster.
Old Jul 2, 2022 | 03:47 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Settings> Vehicle
Vehicle> Alarm
Then Check "Perimeter Sensing"
Old Jul 2, 2022 | 05:19 PM
4wd6.7L's Avatar
4wd6.7L
Settings> Vehicle
Vehicle> Alarm
A lot of owners have tried that only to find it reset to "All Sensors" the next time. That's why some have gone as far as actually disconnecting the interior sensors.
Yours stays set to Perimeter only?
Old Jul 2, 2022 | 06:28 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
So far........
Old Feb 24, 2025 | 11:39 AM
Devil's Advocate's Avatar
Devil's Advocate
My alarm was going off randomly. Getting worse.
Dealer had it checked out after my bad rear axle repaired.
Console intrusion sensor bad. Replacing tomorrow.
DA
Old Feb 24, 2025 | 12:10 PM
B-737's Avatar
B-737
mine often went back to all sensors as well, so i unpluged the sensor for the cabin, its in the overhead bin, solved.
Favored
Feb 14, 2026 12:32 PM
RetiredSoon
6.7L Power Stroke Diesel
13
Jan 5, 2024 12:34 PM
apstang50
Apr 29, 2021 09:04 AM
2019er
Aug 20, 2019 09:53 PM
TIKT B8
Aug 31, 2010 10:20 AM
