Sponsored by: Real Truck
Replacement Gas Tank source for 2001
Old Jul 1, 2022 | 01:16 PM
The Tiger's Avatar
The Tiger
I might need a new tank. It's leaking from the top near the roll over valve. But it might actually be cracked in that spot.
Ford no longer makes it apparently. I have 2001 CCLB gas truck. I was looking at Titan and all their tanks say diesel only. Why would that be? Anyone have a recommendation? I'd rather not get a junk yard tank if that is my only option.
EDIT: Called Titan, their tank vents to atmosphere which isn't a good idea for gas. I've done a lot of web searching and can't find any aftermarket options for this truck.
Old Jul 2, 2022 | 06:41 AM
Tunafish389's Avatar
Tunafish389
Theres a few Ford stores that says they can custom order the tank +$1000! Just search part number
YC3Z-9002-LB.
Old Jul 7, 2022 | 07:32 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Junkyard bro. It’s your cheapest option. Unless you find someone as in private party who is parting one out and has it pulled already. When I parted out my v 10 i sold the gas tank for $100
get a hand pressure pump and grab some hoses and clamps you can pressure test it. The tanks come off easy at the junkyards. Empty, you can zip the straps off quickly also.
Your other option is to drain yours pull it out, fill it with water and then plastic weld the crack. Pressure test it then reinstall it. Obviously drain the water.
Old Jul 8, 2022 | 10:47 AM
Mike1's Avatar
Mike1
Here try Rockauto.
https://www.rockauto.com/en/catalog/...fuel+tank,6268
Old Jul 9, 2022 | 11:47 PM
PJWhelan's Avatar
PJWhelan
Try Also Car-part.com. Look up by part/region whatever but you'll def find a tank out there....Also try a "take off" yard. You pay to get in, find what you need and either you take it off or for a fee, they will. But give car-part.com a shot.
Jax280
Apr 27, 2021 08:34 AM
bluthundrgal
1997 - 2003 F150
Nov 4, 2007 06:22 PM
spudtang92
Mar 19, 2006 04:32 PM
