Carb guidance
Old Jun 30, 2022 | 01:57 AM
triorez25's Avatar
triorez25
Carb guidance
To start with i know there's a pinned carburetor guide but I'm still going to ask directly. I need to get a new carb for my 84 351w 2bbl and I'm unsure which one to get I'd rather not go through the hassle of converting to a 4bbl on a stock motor but i want a bit a performance boost looking for holley preferably
Old Jun 30, 2022 | 05:56 AM
Franklin2's Avatar
Franklin2
Some of the 351w 2 barrel engines had computer management. Before you start modifying your engine you need to determine if you have computer management. To do so, look at the distributor. If it has a rectangle shaped module mounted to the side of it with a bunch of wires coming out, and does not have a vacuum line going to the distributor, then you do have computer management and to do any modifications you will have to swap the distributor out when you do your carb change.
Old Jun 30, 2022 | 07:43 AM
triorez25's Avatar
triorez25
roger I'll look into that
Old Jun 30, 2022 | 10:00 AM
BigBlue2's Avatar
BigBlue2
I'd stick to the 2bbl unless burning rubber is your thing. I had all the acceleration I needed with a 2bbl Holley on my Chevy 1/2 ton 350 with an AT properly set to drop to passing gear. Punch and Go!
At today's gas prices a 4bbl doesn't make sense for a working truck.
Old Jun 30, 2022 | 04:42 PM
Franklin2's Avatar
Franklin2
A 4 bbl can actually get better fuel mileage than a large 2 barrel. I believe Holley sells a 350cfm and a 500 cfm 2 barrel aftermarket carb. I bet you get better fuel mileage from a 600 cfm 4 barrel than the 500 cfm 2 barrel if you keep your foot out of the 4 barrel and never open the rear barrels. You would think the 600 cfm 4 barrel is 300cfm in the front and 300 cfm in the back.
Old Jun 30, 2022 | 05:53 PM
BigBlue2's Avatar
BigBlue2
Those are maximum flows. You don't need to have your two barrel open any further than the front two of a four. But when the 4bbl reaches 300 you have to go to 4bbl to get to 350 where the 2bbl can get there on two.
If you're gonna keep your foot out of it, which is doubtful, you may as well go for the 2bbl. I was getting 18 to 20 mpg with the stock 2bbl Holley. The GTO with the four barrel used gas like there was a leak in the tank. A fun ride though.
Old Jun 30, 2022 | 07:32 PM
triorez25's Avatar
triorez25
Fair enough
Old Jun 30, 2022 | 08:34 PM
triorez25's Avatar
triorez25
Well there's no module and there is a vacuum line is there anything else i might want to check?
Old Jun 30, 2022 | 08:40 PM
triorez25's Avatar
triorez25
Old Jul 1, 2022 | 02:11 AM
Ken Blythen's Avatar
Ken Blythen
A few months ago I scrapped a Motorcraft 2150 that was on my 351W, in favor of a 350cfm Holley 2-barrel carb (a Street Avenger....which is a later version 2300).
There are several similar versions of this carb but Holley recommended the Street Avenger. The 2150 had been rebuilt not too long before, but was a smaller venturi model off a 302.
The swap to the Holley was a win/win......more power & better mpg. I had wondered about going to the 500cfm version, but there is no sense of the smaller carb being restrictive at all.
I seldom run over 3000rpm, & the original 2-barrel carbs on 351W's were also 350cfm.
The only thing I don't like is the aftermarket-type electric choke, but otherwise very pleased.
The bolt pattern is also a match to the original 2-barrel intake manifold.
Old Jul 1, 2022 | 05:57 AM
triorez25's Avatar
triorez25
Damn that choke does soubd kind of annoying. I'll have to keep that in mind thx
Old Jul 1, 2022 | 06:48 AM
Franklin2's Avatar
Franklin2
You are good to go. Be prepared for adapting the fuel line location and the throttle hook-up. You should run a external fuel filter before the carb, so you can just cut the factory line short and install a aftermarket fuel filter with fuel hose in between the old fuel line and the carb.
Old Jul 1, 2022 | 06:58 AM
triorez25's Avatar
triorez25
Roger I'll keep the fuel and throttle stuff in mind someone else on the thread recommended a 350cfm street avenger do you have an alternative recommendation
Old Jul 1, 2022 | 07:08 AM
Franklin2's Avatar
Franklin2
No recommendation. I am cheap, when I run a 2bbl carb I get a cheap knock-off made in China one from Amazon or Ebay. I either do that or round up a used Holley 4bbl and a used cast iron Ford 4bbl intake and run that.
Old Jul 1, 2022 | 07:25 AM
triorez25's Avatar
triorez25
Fair, I'd consider a 4bbl but this motor is 100 percent stock and I'm not ready to make the changes needed to use a 4bbl effectively
