Carb guidance
Old Jul 1, 2022 | 03:09 PM
Franklin2's Avatar
Franklin2
Originally Posted by triorez25
Fair, I'd consider a 4bbl but this motor is 100 percent stock and I'm not ready to make the changes needed to use a 4bbl effectively
Other changes are not really needed for it run good. Ford added the 4 barrel on a stock 351w and called it a 351wHO. They also did it on the first mustangs. They came with a slightly different cam than the 2bbl engines, but the difference was very slight.
Opening up the exhaust does help, but you can do that later. The stock aircleaner even fits the 4bbl.
Old Jul 1, 2022 | 05:27 PM
triorez25's Avatar
triorez25
Huh i was told that without considerable attention 4bbl would allow for too much fuel
Old Jul 1, 2022 | 05:47 PM
Ken Blythen's Avatar
Ken Blythen
Not if it's a correctly sized, vacuum secondary carb.
Old Jul 1, 2022 | 08:08 PM
Franklin2's Avatar
Franklin2
You can use a Holley #1850 which is a 600 cfm vacuum secondary, and it will run great right out of the box. I have done several back in the day, and they were brand new carbs. That was back when they were $150 each. I see now they are over $400 each.
jklapp86
Jun 3, 2008 08:57 PM
nastruk95
Dec 5, 2004 08:55 PM
DT 466Man
Oct 21, 2003 10:32 PM
onestep
Jan 7, 2002 06:19 AM
