Neutral Safety Switch
Old Jun 28, 2022 | 06:50 PM
DX323's Avatar
DX323
I've been working on rewiring my 66 F100 with three on the tree. Been having trouble, but finally realized I was needing to wire the Purple Solenoid wire to the neutral safety switch. Problem now is trying to figure out how to get to the Neutral Safety Switch in the steering column? Any tricks to help me get to it?
Old Jun 28, 2022 | 07:32 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
This is a manual transmission, right? No NSS.
Old Jun 29, 2022 | 01:48 AM
66F250_4x4's Avatar
66F250_4x4
For a manual transmission, you do not have a neutral safety switch.
Your AAW harness kit is designed like this:
Purple wire 5 "Neutral Safety Switch" is Hot when the ignition is turned to START. It can be wired to the NSS, and then the NSS will only allow START to pass through if in Neutral or Park.
Purple wire 6 "Starter Solenoid" is included in the harness to run from the other side of the NSS out to the starter solenoid.
If you have a manual transmission w/o a NSS, then you will wire purple wire 5 "Neutral Safety Switch" directly out to the starter solenoid. When you turn the ignition to START, the solenoid will engage.
You can remove purple wire 6 "Starter Solenoid" from the harness, or wrap it up.
Old Jun 29, 2022 | 12:31 PM
retired ironworker's Avatar
retired ironworker
How about incorporating the NSS onto the clutch pedal like a brake light switch?
Denty
Apr 27, 2021 02:02 AM
EPDP99
May 9, 2006 07:43 AM
RICHMC54
Dec 5, 2004 05:18 AM
66MercMan
Oct 5, 2004 08:35 AM
Phaeton16
1966 - 1977 Early Broncos
Dec 11, 2001 10:33 AM
