headlight buckets??
Old Jun 28, 2022 | 05:41 PM
emeraldcoupe's Avatar
emeraldcoupe
headlight buckets??
are the 67-72 headlight buckets the same? i need a pair for my 71, but seems everywhere lists 67-69 only.
Old Jun 28, 2022 | 06:05 PM
JJS72XLT's Avatar
JJS72XLT
Assuming 1971 F-100/F-350 -- appears base part number 13118 (RH) and 13119 (LH) were for 1970 - 1972. If my info is correct, then 1970 - 1972 would be D0ZZ-13118-A for RH and D0ZZ-13119-A for LH.
Old Jun 29, 2022 | 07:03 AM
Dans72's Avatar
Dans72
I bought mine from Carpenter in Charlotte, NC. They fit perfectly, but be sure to get all new screws, springs and attachment hardware. It makes the job sooooo much easier!
Old Jun 29, 2022 | 07:43 AM
gangstakr's Avatar
gangstakr
They are different. If you put them side by side you can't tell. The 70-71&72 buckets will fit in 67-68&69 as well as the other way around. Problem is your headlights will be about a quarter turn off. You won't get a proper adjustment. Basically you need the correct buckets for your application. As stated by JJ72XLT, get the right ones needed for your truck.
Old Jun 30, 2022 | 07:24 AM
emeraldcoupe
found the correct ones from MAC. my go to is NPD but they didn't list them. actually found them at LMC, but......
Old Jun 30, 2022 | 10:59 AM
DisneysPatB's Avatar
DisneysPatB
NPD gets theirs from DC, both of which are out of stock. You have to hunt from them, they don't call them buckets on NPD, but doors.
Product Search - National Parts Depot (npdlink.com)
Old Jun 30, 2022 | 11:16 AM
emeraldcoupe
Yeah, but I wasn't looking for the door, I needed the bucket.
Old Jun 30, 2022 | 11:37 AM
DisneysPatB
Ahhhh yes. My bad. I do need the doors, but they are on back order.
Old Jun 30, 2022 | 11:58 AM
emeraldcoupe
All good, I appreciate the reply
ovenrat
2004 - 2008 F150
Feb 8, 2022 02:02 PM
Grass Lake Ron
Dec 4, 2021 12:36 PM
gangstakr
WTB - Parts & other
Dec 28, 2012 08:00 PM
jelks
Mar 22, 2004 11:47 AM
