Sponsored by: Real Truck
Interchageable??
Old Jun 28, 2022 | 11:57 AM
Rangerforever's Avatar
Rangerforever
Interchageable??
My truck is a 2008 F250 SD 5.4L auto 4WD. I have a problem with the transfer case module that I posted about earlier. I can get a module but slightly different number. Mine is 7C3T-14B205-AA. I found one locally but it is out of a 2008 F350 diesel 4 wd. The number is 8C3T-14B205-AB. Will it work in my truck? I am out $150 ordering from out of town so not keen on ordering another.
There is only one wiring diagram for the 2008 F250 SD 4WD and both of those boards are used in the truck so the pinouts must be the same. Likely just a difference in programming. Does anyone out there know what the difference in the two versions is and will it work in my truck?
Thanks for any advice
Old Jun 28, 2022 | 12:09 PM
ifrythings's Avatar
ifrythings
It should work, the only difference I have found was in 2010 and the difference was how it mounted. What is yours not doing right?
Old Jun 28, 2022 | 01:13 PM
Rangerforever
Took my garbage to the dump, backed up and when I moved forward to leave the 4x4 high lite was on and it was engaged in 4 wd. It will not disengage. I removed the shifter motor and it runs fine both directions. Checked all the wiring and everything is good for continuity. I did test P7 from the Mitchel info and it should get 5 volts on the MSS switch connector pin 3. I get 0 volts. The fix is replace the module in the Mitchel info. I can remove the shifter motor and electrically move it back to the 2 WD position. I can manually shift the transfer case to 2 WD. When I reinstall the shifter motor and select 4 high it moves to 4 high (lite comes on and it is engaged). When I try to go back to 2 wd it does not move. I can do that with the shifter motor off the transfer case and watch it. I also bench tested the module by connecting power and ground to the appropriate pins and checking the pin that should give 5 volts and it is 0 so definitely a module problem.
When I looked at the pinout and it is the same I can't see any damage being done to anything else but I would like to be sure. My guess is that there is a simple program change.
Old Jun 28, 2022 | 01:40 PM
ifrythings's Avatar
ifrythings
What do you get for voltage on pin 2 of the MSS switch?
Old Jun 28, 2022 | 03:24 PM
Rangerforever
I did so many tests using the Mitchel Pinpoint tests I cannot recall for sure. I believe it was 10.8 volts and should be 0. I will go out later and recheck all of them and post it.
Thanks for the help.
Old Jun 28, 2022 | 04:00 PM
Rangerforever
I repeated Mitchel Pinpoint Tests 6 and 7.
PP test 6 Key On C281B disconnected Check voltage on MSS pins 2 and 3 Voltage is 0 on both. It should be 0 volts so it passes the test. It only makes sense since power to the module is provided through C281B pins 1&2 and ground through pin 3. With C281B disconnected there should be no voltage.
PP Test 7 Key On C281B connected Check voltage on MSS pin 3 11.2 volts It should be 5 volts so fails the test. This voltage is there with the key on or off. The supply is through fuse 40 which is hot at all times.
Check voltage on MSS pin 2 0 volts Not part of the Mitchel test.
Rangerforever
Oct 1, 2022 08:37 PM
Dusty Nelson
Mar 15, 2021 09:56 PM
cbrown123
Apr 25, 2016 05:22 PM
Outbreaker
Jul 9, 2015 03:04 PM
whybnormal
Oct 14, 2007 10:09 PM
