truck pulling/drifting
Adjustable radius arms are on my list. however, if there is an obvious problem I can fix before dropping all that money on them, that is the better route. I would hate to spend all that money and still have an issue. Call and talk to them. I can't remember his name. I have a level with rear Blocks and 35s on 20x10 -18 wheels. That wheel contributes. I wish I had got inovate wheels in hindsite but have a lot to consider to change...not to mention price.
Here it is clocked to negate the camber. We tried this but did not have radius arms at the time and the cross caster was way off and it pulled really hard. I still have to go in and adjust this...maybe next week, reset the allignment and then drop the pressure in the steering stabilizer.
Here it is set to Carli directions.
Here it is clocked to negate the camber. We tried this but did not have radius arms at the time and the cross castor was wayboff and it pulled really hard. I still have to go in and adjust this...maybe next week, reset the allignment and then drop the pressure in the steering stabilizer.
what was your camber reading? before adjusting the shim?
what was your cross caster and which direction did it pull?
did this correct anything or make it worse?
Are you running stock wheels ?
aftermarket wider wheels with more offset to the outside will cause different steering & pulling issues
most AT & MT treaded tires cause issues like this but people insist on running them.
swapped back to stock wheels and tires to troubleshoot. still does it
it did great on a 11,135 loop up & out West.
Sure glad I spent the $$ on PMF Adjustable Radius arms to dial in the needed extra caster in all the straitline wind across SD MT WY ID & WA areas
Here it is clocked to negate the camber. We tried this but did not have radius arms at the time and the cross castor was wayboff and it pulled really hard. I still have to go in and adjust this...maybe next week, reset the allignment and then drop the pressure in the steering stabilizer./QUOTE]
is this your driver side?
Current allignment (still need to counter a slight left drift at higway speeds. Nittos have left radial pull and my steering stabilizer is pushing that way. I will not change the steering stabilizer until I fix the camber. My target for allignment is no wondering or pull at highway speeds towing a moderate heavy load).
Driver/Passenger (after radius arm install)
Toe: 1mm Toe-In. 2mm Toe-in.
3mm Total (target 3.2mm= 1/16")
Camber: -0.8 -0.4
Caster: 4.2 4.65
after level kit (* denotes out of spec).
Dvr. Pass.
Camber: -1.1* 0.0
Caster: 3.2 3.4
Toe: 0.0 0.0
Original alignment.
Dvr. Pass.
Camber: -0.07 -0.42
Caster: 4.18* 4.67*
Toe: 0.0 0.03
Factory Specs: (Min, pref, max)
Dvr. Pass.
Camber: -0.6, .15, .9. -0.6, .15, 0.9
Caster: 1.5, 2.80, 4.1 1.8, 3.10, 4.4
Toe: -.07, .05, .17 -.07, .05, .17
you have since added radius arms and the shim is back in the "normal" direction? are you back to stock shims?
camber is at -0.8 after the radius arms?
I kept the 2* caster bushings because i dumped the stock ones (dumb mistake) i keep everything usually. I haven't gotten around to fixing the camber because it doesn't really do anything. When I dialed in more caster with the radius arms I didn't need to. Eventually I'll get around and play with it. I'll need to clock that to where the shop had it then I'll measure the camber and caster to see how close it is to where i want. Then I'll probably set the radius arms up to have cross caster to compensate for losing some of the caster by changing the camber. Then measure everything throughout the process. It just takes a bunch of time...or money.
did cjc or carli give you any idea what the change in camber would be by clocking that shim?
how much cross caster did the tech say it had that would make it pull hard left?
i am just trying to figure out if I should even mess with with that driver shim or not.
wish I had an alignment machine, I could do all of this myself.
i don't want to keep throwing money at a shop that doesn't know what they are doing, or what the truck needs
sounds like the real way to fix this is with the radius arms. they have been on my short list of truck parts 😏
That's what I did. There were some other videos I looked at which talked about calculating the caster, too. Our trucks have a steering angle screen which made getting the directional angle of the wheels easier. You have to be on a perfectly level piece of ground and then when you use the angle finder I put it on a piece of angle iron. This needs to go the entire length of the diameter of your wheel, edge to edge. My aftermarket wheels were 1/2" bigger diameter than the stock wheels and not going edge to edge was throwing off the camber reading...which throws off your caster calculation.
sure it cost a little more BUT your driving a big expensive rig so what’s another grand & change you know.
PLUS you leave all the camber bone stock not disturbing it OR NEEDING AN ALIGNMENT.
you may need to tweak drag link a 1/2 turn or so to center steering wheel but no big deal.
no way I’m disturbing my stock bushings getting it all out of whack lol
I've only posted well over a dozen on this exact issue. But here I go again...
Your pull isn't from caster, or tires, or stabilizers. It's because one side has 1 degree of camber and the other side doesnt. Even from the factory, you will have about .25 to .5 degrees more on the passenger side to account for road crown. A solid axle vehicle should have zero (or as close to 0 as possible) of camber, 4 to 5 of caster, and about .1 to .2 degrees of total toe in (positive toe).
When it comes to alignment, it's not just one thing that will cause an issue. A combination of all those things are working to get you down the road straight. Some will play more than others, but it's still everything coming together.
Find a new shop. there is zero reason it should have left that way. I would also add a tiny bit more toe. Find one that will actually deal with the camber and caster adjustment (most will say you can't change it, the fact is they're just lazy and not wanting to spend labor on such a cheap service)
You can rotate the ball joint slug one notch to help get rid of that camber, but you will also take away caster. If it were me, I would rotate the slug one notch (rotate it so the slot is at the 7 to 8 o clock position when looking down) and take it in to a good shop. You might be close
What he needs to do is put that other cam in to bring the over positive side to meet the other side, and put the wheels and tires on that will be the main stay and have the alignment rechecked. Changing caster will change the toe, reducing the positive side will bring more toe in and move the steering wheel a bit.
