Power window conversion
Old Jun 24, 2022 | 07:55 AM
bobs 80 f250's Avatar
bobs 80 f250
Has anyone converted their manual crack windows to power? I bought a set of universal power window cranks of eBay, but the plastic gears that basically raise and lower the windows strip out. I have all the wiring in place and just want to know if I can swap in the power window regulators. Thanks
Old Jun 24, 2022 | 01:11 PM
Franklin2's Avatar
Franklin2
Here's a guy that did it awhile back. https://www.ford-trucks.com/forums/7...o-81-f150.html
Old Jun 25, 2022 | 08:09 PM
xlt351's Avatar
xlt351
Trailering
Hey,
My 1983 F100 XLT only came with manual / crank windows, but I bought these off ebay ( https://www.ebay.com.au/itm/37092662...3ABFBMrLe22LNg)
Then ran power to the doors from the engine bay.
However, I bought these ( https://www.autoloc.com/catalog/Powe...s-All-Vehicles ) so I could use the OEM crank handles. Works well and looks original.
When fitting the new power actuators be mindful that they dont bolt into the same holes as the manual ones. You will see little dimples in the door for you to drill alternative holes.
Old Jun 26, 2022 | 08:28 AM
bobs 80 f250
Thanks for the info. Do any of the holes from the manual regs line up, or do I need to redrill all new holes?
Old Jun 26, 2022 | 09:16 PM
reamer's Avatar
reamer
Easier to buy Bronco doors and do the swap, that way you get the wiring harness that goes across the dash.....
Old Jun 26, 2022 | 09:27 PM
xlt351's Avatar
xlt351
Trailering
Well as i did this a few years ago, i think one hole does
bobs 80 f250
Oct 19, 2021 08:30 PM
pchelp
Aug 12, 2017 08:10 AM
fast58
Mar 5, 2012 07:06 PM
Monster 78 F-150 4X4
2004 - 2008 F150
Oct 14, 2004 07:57 PM
