92 4.0 sensor problem?
Old Nov 9, 2003 | 08:35 PM
srx700's Avatar
srx700
ranger 4.0 will start fine and then idle about 2000 rpm for about 10 seconds and then will stall. if it has been warmed up it will idle but very rough. code said TPS so replaced that, no help so then replaced IAC and MAF and also spark plugs. the truck has about 130k miles on it. Thanks in advance for any help or tips.
Old Nov 9, 2003 | 08:50 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
Have you pulled the codes again? Did you run the pinpoint test for the first code?
Old Nov 9, 2003 | 09:11 PM
srx700's Avatar
srx700
yes pulled codes again and this time there weren't any..I'm not sure what you mean by " pinpoint " test.. thanks
Old Nov 10, 2003 | 02:11 PM
aletheuo's Avatar
aletheuo
Get up to normal operating temp and then pull the wire off the ECC engine temp sensor. If that clears it up then replace the sensor.
Old Nov 10, 2003 | 04:20 PM
Ken00's Avatar
Ken00
Pinpoint tests are used to determine the exact cause of the code, a single code can have many possible causes. Did you run the key on engine running test for codes?
Roy C. Cascio
Mar 2, 2010 11:57 AM
Mr. Man
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 31, 2005 11:55 AM
dheat
Feb 7, 2005 10:48 AM
Ben Alston
Nov 4, 2004 08:02 PM
94 ford
Aerostar
Jan 26, 2001 11:29 AM
