Stuck injector? Now what?
Jun 22, 2022 | 09:56 PM
Only thing I can think of is a stuck injector. Any remedy besides new sticks?
bare with me while I remember how to upload a video, obviously attaching it doesn’t work.
https://youtube.com/shorts/9PwTjBiHwX4?feature=share
maybe that works?
Jun 22, 2022 | 11:04 PM
Don't drive it any more. Might have a tip cracked and ready to fall off.
Jun 22, 2022 | 11:23 PM
Quote:
Originally Posted by
Kwikkordead
only way to check is pull the injectors? What would cause a cracked tip?
Jun 23, 2022 | 06:42 AM
VegasFordSD
I cannot say it IS a cracked tip, but that sound and cloudy exhaust is strong indication of way too much fuel injected each time it's called for in the Otto cycle. Only way to fix that is to figure out the offender and replace it, or just bite the bullet and do them all.
Jun 23, 2022 | 07:45 AM
That would definitely be representative of bad injector(s).
Jun 23, 2022 | 07:55 AM
A HEUI injector cannot get "stuck on" and inject fuel constantly like a common rail injector can.
I'm with Kwikkordead. I think you have a nozzle issue and continuing to drive it like that will cause piston damage.
no matter what you're going to have to pull those sticks! maybe just a bad oring?
Jun 23, 2022 | 08:00 AM
cleatus12r
A bad injector can inject fuel with the pressure of the fuel pump.
Jun 23, 2022 | 09:32 AM
Thanks guys, appreciate the feedback. Shortest life span on injectors I’ve ever had.
Jun 23, 2022 | 09:33 AM
VegasFordSD
Can you provide more data?
Jun 23, 2022 | 09:39 AM
Bitterroot Diesel
I have access to AE, just would need to find time to run any tests and get data.
Jun 23, 2022 | 10:31 AM
Brand, miles on your injectors?
Jun 23, 2022 | 11:02 AM
Bitterroot Diesel
Unlimited Diesel 238/80’s
About 4 1/2 years old
under 80k miles
Jun 23, 2022 | 11:09 AM
80K is decent mileage for a reman.
Jun 23, 2022 | 11:24 AM
Bitterroot Diesel
Ok, thanks… really only had my last set from Full Force to compare, had 150k+ on them and still strong before the truck decided it was too cold outside 😂 (see sig picture)
