2006 explorer - Possible bad pcm?
Old Jun 22, 2022 | 12:42 PM
83sd's Avatar
83sd
Good Morning Gents,
I am working on my inlaws 2006 explorer 4.6l that has a mess of codes. Truck runs great and has plenty of power. It has a reoccurring p0135,p0141,p0155p0645, & p0443.Looking at the wire schematics, these all have a positive feed off of the battery distribution and then are switched via ground from the pcm. I have 12v+ at all of these connections. With just a meter on the o2 sensor heater circuit for back 1 sensor 2, I have 12v+ and ground until I put a load on the circuit. As soon as I load it, the ground reference drops out. I can load the positive side and put my test bulb to a frame ground no problem. o2 sensor heater elements meter at 4ohms.
I have the same issue on the purge valve circuit, but I can control the purge valve to the on position with my scan tool. This is making me question the pcm. Am I missing something? Any help would be greatly appreciated.
Redbeard1475
Jun 6, 2018 09:14 PM
Alcaeus
Aug 6, 2016 09:48 AM
mikeheckler
1997 - 2003 F150
Sep 17, 2015 11:38 AM
lazarus27
1997 - 2003 F150
Aug 16, 2015 09:26 PM
kidzstang
1997 - 2003 F150
May 15, 2005 09:03 AM
