Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Water Pump?
Old Jun 22, 2022 | 06:39 AM
texczech's Avatar
texczech
Water Pump?
Need to locate a water pump for this truck-N60EV055254- Should be a 73 F600 330 V8. Thanks!
Old Jun 22, 2022 | 06:28 PM
85e150's Avatar
85e150
N60 = LN600 gas. You will have no end to your troubles calling this truck a '73 F600 with a 330. Some stuff interchanges, some does not. See below for the illustrations showing the difference.
E = 361 4V XD FT gas V8. Again, there is a lot of interchange with the 330 HD, not quite as much with the 330 MD.
V = Kentucky Truck Plant
055254 = 1977 numerical series. (1973 numbers start with "Q", "R" or "S")
What leads you to believe it's a '73 F600?
Illustration, F vs. LN etc:
https://cimg3.ibsrv.net/gimg/www.for...7d9b6f01c6.jpg
Some info regarding the water pump and the address of a rebuild outfit:
https://www.ford-trucks.com/forums/1...l#post19385266
I tried NAPA (you have to change vehicle type to "Medium Heavy") and didn't get a hit.
There were some on Ebay, but make sure you are getting the same pump if you go that way:
https://www.ebay.com/p/1471364108
Old Jun 25, 2022 | 03:18 PM
Destroked 450's Avatar
Destroked 450
Need to know what truck you have, most F models had a standard pump with the fan mounted on the end of the pump shaft
Most L models used a different pump that mounted a separate fan hub up high on the pump
Standard F series water pump
L series high fan mount water pump
Old Jun 27, 2022 | 04:23 PM
texczech's Avatar
texczech
Yes, guys, this is a LN style.... it has the flip over/ hinged front end. I am not sure if it has the high mount fan or not. When I get back to the truck again, I will check. Thanks for getting me straight on the model. Don't know why I got confused a bout what I had.
Old Jul 5, 2022 | 08:34 AM
texczech's Avatar
texczech
Okay- I have the fan mounted to the water pump pulley- like a conventional fan & pulley system- any part numbers for this style of pump. And thanks for getting me straight on what I was looking at!
Old Jul 5, 2022 | 06:13 PM
85e150's Avatar
85e150
The Ebay link in post 2.
Or NAPA:
https://www.napaonline.com/en/p/WP_5...pressionRank=1
BRIAN NORCAL
Jul 17, 2017 11:30 AM
waltharper
Oregon Chapter
Dec 3, 2014 12:53 AM
fordflaresides
Apr 21, 2005 09:46 PM
fordguy101
General Automotive Discussion
Apr 14, 2005 10:40 PM
