hood hinges...
Old Nov 9, 2003 | 06:46 PM
Coley's Avatar
Coley
hood hinges...
okay,so today we got the hood lined up fair(about as good as the stock thing is gonna get for us)and it won't stay up!Whenever we raise it,it slowly goes back down to less than a foot from the latch...we sprayed WD-40 at all five pivot points last week trying to get it to work right...did we mess up bad?Other than that,it is working fairly well...thanks...
Old Nov 9, 2003 | 06:51 PM
gtkane's Avatar
gtkane
Coley
When you get it figured out,let me know. Mine did that too, before I took it apart and cut it up.(nothing bad,just cab mods)
Graham
Old Nov 9, 2003 | 06:54 PM
himmelberg's Avatar
himmelberg
Did you replace the springs? Could be they have lost their umph. himmelberg
Old Nov 9, 2003 | 06:59 PM
gtkane's Avatar
gtkane
Springs.............sometimes we overlook the obvious.
Graham
Old Nov 9, 2003 | 08:02 PM
fatfenders's Avatar
fatfenders
I recall Coley said he installed new hinges. If the hinges are also new, I suspect they are 1/2 turn too loose. This is what my hood did after I installed the new springs in mine. May be time to don you helmet and athletic cup and let the fun commence. Ensure your loved ones know your blood type and be careful. Do you have a spring installation tool? AKA short piece of exhaust pipe with a notch? Yell if not and we'll describe this marvelous tool that barely works.
Old Nov 9, 2003 | 09:23 PM
Coley's Avatar
Coley
Yes,the hinges and springs are new...I bought new hinges and they came assembled with new springs...don't tell me I have to mess with those springs...I know they are dangerous...
Old Nov 9, 2003 | 09:29 PM
fatfenders's Avatar
fatfenders
Coley
I mispoke in my last post but you figured it out I see. I can't tell for sure without looking but it sounds like you need to re-install with 1/2 turn more preload. My hood did the exact same thing. I bought a tool that amounted to an 8 inch piece of exhaust pipe. A small square notch will catch the spring. The other end of pipe needs a hole drilled through both sides so you can turn it with a large screwdriver. Wear safety goggles and gloves for sure.
Old Nov 9, 2003 | 09:32 PM
DS02F250's Avatar
DS02F250
A broken broom handle makes an awesome hood support
Hi-tech, baby... yeah!!!
Butch n Me
Old Nov 9, 2003 | 09:37 PM
fatfenders's Avatar
fatfenders
Butch n Me
Daryl,
Sadly, that works a lot better than Henry's idea. I am not going to miss my stock hinges when the tilt is installed on mine soon.
Old Nov 9, 2003 | 09:55 PM
Coley's Avatar
Coley
Terrific...$150 for new hinges and now a good shot at serious injury...I'll just get me a long piece of thick dowel rod tomorrow...cause I ain't taking none of this stuff back off...
Old Nov 9, 2003 | 10:18 PM
Coley's Avatar
Coley
Sorry...I'm back now...didn't mean to be rude...I think I'm gonna try to get some of that slickem off of there tomorrow and see if that helps...thanks for the words of wisdom.
Old Nov 10, 2003 | 07:02 AM
55Bubba's Avatar
55Bubba
Coley
the slickum is not the problem. As with most of us who have replaced hoods, springs, entire hinge sets etc. , each hood is slightly different. The reason your hood is dropping is that the hinges are trying to hold up a big mass of metal. As Dewayne said, you need to tighten the springs one half turn. I did it on mine and it was a biblical experience, ie, crying, gnashing of teeth and sitting in sackcloth and ashes and blood (mine). FAB A TOOL, steal a tool, borrow a tool, You can't do it with channel locks, trust me. I still am missing a chunk out of a finger.
Wear eyewear, footwear, gloves, bulletproof vest, chain mail suit.
Or go to a flip hood.
Best
Bubba
Old Nov 10, 2003 | 08:59 AM
Coley's Avatar
Coley
The hinges would hold it up before I sprayed that on there...no chance?
Old Nov 10, 2003 | 01:19 PM
55Bubba's Avatar
55Bubba
It may have held it up because of the friction/rust and then you reduced the friction. Bottom line is that the more you used it and broke the rust through, the lower the hood would have sunk.
Bubba
Old Nov 10, 2003 | 02:48 PM
Jag Red 54's Avatar
Jag Red 54
In all fairness I must say that trying the sticky spray is necessary. Will it work? Probably not, but it may. I believe in doing the easiest cheapest things first! I don't know what you had in mind, but I was thinking some sort of spray adhesive. If it doesn't work, then you can clean it all off when you take the hinges apart someday. Good luck, John
