No fuel issue
Old Jun 18, 2022 | 03:13 PM
Troylj's Avatar
Troylj
8th Gear
No fuel issue
My 94 f150 5.8 went for a swim a few months ago. I drained the tanks, filled with fresh premium gas, new fuel filter, plugs, oil/filter. Computer got toasted so I’ve replaced it with an exact match. I can only get it to run if I dump gas down the intake. I have a pressure gauge on the rail and I’m running good pressure koeo and while running. Runs pretty decent when it’s running but will die out as soon as the gas from the intake is gone. What are good areas to check?
Old Jun 18, 2022 | 03:35 PM
sswari's Avatar
sswari
What would good pressure be? Does it drop off as the engine is running or stay constant? Are the injectors firing? There is very little between the rail and the injectors that could restrict fuel flow except non-firing injectors.
Old Jun 18, 2022 | 04:15 PM
Troylj's Avatar
Troylj
8th Gear
I get almost 40 when cranking and with running and giving it some juice it was about 65
Old Jun 18, 2022 | 04:46 PM
Troylj's Avatar
Troylj
8th Gear
I don’t think the injectors are firing. Looking for things to check as to why. What tells the injectors to open?
Old Jun 18, 2022 | 05:50 PM
sswari's Avatar
sswari
The ECU, if you did not get the exact one or the one you have is dead, this could be it. however I would think that if it is even close, there would be some fuel for it to fire from. Is this truck stock other then that which you replaced due to flooding?
Old Jun 18, 2022 | 05:54 PM
sswari's Avatar
sswari
is there a crank shaft position sensor? maybe a cam shaft sensor? there could be a few other items that may not be getting correct info to the ECU. Distributor comes to mind as well.
Old Jun 18, 2022 | 06:01 PM
Troylj's Avatar
Troylj
8th Gear
It is the exact match ecu and not a used one. I could check those sensors. Just an ohm test for resistance? Would that let the truck run fine while dumping fuel down the intake though?
Old Jun 18, 2022 | 06:12 PM
sswari's Avatar
sswari
Be careful with "Exact Match" and "Not Used" unless somebody had one sitting on a shelf somewhere, it's at the very least remand.
As for testing the sensors, you would have do to some research. I am just tossing out other options. The ECU is the final step in when/if they fire based on several other factors.
Old Jun 18, 2022 | 06:31 PM
WWR's Avatar
WWR
I also question if your injectors are firing. You should be able to check with a noid light, search YT if you're unsure of the process
Old Jun 18, 2022 | 07:11 PM
Troylj's Avatar
Troylj
8th Gear
I should have said this one is rebuilt not brand new. Does anyone know the order of operations to get injectors to fire? Ecu being the last step?
Old Jun 18, 2022 | 07:22 PM
WWR's Avatar
WWR
I honestly don't, but EEC-IV is pretty simple. I imagine it wants to see a tach signal (maybe I'm wrong) but yeah ECM tells injectors to fire. It's just batch fire so one side then the other.
Old Jun 19, 2022 | 03:48 PM
Troylj's Avatar
Troylj
8th Gear
Still confused. I thought maybe it was the pip in the distributor. I took the distributor out and connected a ground clamp to it. While I turned the distributor gear I could definitely hear the injectors opening and fuel pump sending more fuel. Still won’t run with out fueling manually though
hambone1234
Sep 1, 2021 04:15 PM
kyacklich
Jan 13, 2014 08:27 PM
mule clipper
15
Sep 12, 2010 10:43 AM
derblitz
1978 - 1996 Big Bronco
28
Jan 4, 2006 04:51 PM
GmanPride45
Aug 29, 2001 12:57 PM
