1995 F-150 FWD FUEL PUMPS 302
Old Jun 17, 2022 | 05:09 PM
righttoown's Avatar
righttoown
1st Gear
Going to replace original fuel pumps after cleaning out both tanks. Any suggestions on where to buy them from? Are some better than others?
Thanks
Old Jun 18, 2022 | 05:40 AM
Mudsport96's Avatar
Mudsport96
As long as you can find a motorcraft id say anywhere is a good place to buy.
I had the original fail at 170xxx miles put in an airtex from orielly and it crapped out in 30000 miles. Put in a used motorcraft and it is still going 100k later.
Old Jun 18, 2022 | 05:58 AM
2dwoods's Avatar
2dwoods
Use oem,go on line and search oem ford parts theres alot of ford dealers that have better prices than your local dealer so look around they ain't cheap
Old Jun 18, 2022 | 06:36 PM
WWR's Avatar
WWR
I put an Airtex in the rear of an '87 F150 and the fuel gauge never read correctly after that.
For '90+ (single in-tank pump) I actually don't know if they still sell it as JUST the pump and white plastic enclosure where you have to pry it off the hard lines? Or are they sold as complete modules with sender these days? Whenever I did them it was the former, I always hated wrestling it off the seemingly fragile hard lines
Old Jun 18, 2022 | 06:56 PM
spurredon's Avatar
spurredon
Maybe not an issue in MS, but up here in the land of rust, anytime I have to take the tank out for a pump, sender or whatever, I put in a new tank as well. Of course, unless it is virtually new already! LOL
Old Jun 19, 2022 | 06:37 PM
Scndsin's Avatar
Scndsin
Most tanks can look great on the outside, but inside, condensation settling out + trash can eat it inside out.
Tank walls looked the same.
locknload
Dec 31, 2010 12:54 PM
TONINA
Oct 20, 2004 04:59 PM
rrich600
May 24, 2003 07:53 PM
