Vacuum System Problems
Old Jun 17, 2022 | 04:52 PM
Jerry Cox's Avatar
Jerry Cox
2nd Gear
I have a 1988 F-250 with a 7.3 idi naturally aspirated. I'm owner number 6 and the previous 5 screwed this thing up. There are a lot of lines in general that got cut. The vacuum system is just dry rotted and old. Its got some vacuum issues, but it still runs and drives. I started to pull lines, and me being an idiot, didn't take pictures or a video
I was wondering if anyone had a vacuum diagram for a naturally aspirated 7.3.
Thanks
Old Jun 18, 2022 | 06:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
there are really only two things that need vacuum. the brake power booster, and the ac/heat controls.
well, three if you have a C-6 trans. the trans modulator needs vacuum to shift.
Old Jun 19, 2022 | 02:40 AM
Jerry Cox's Avatar
Jerry Cox
2nd Gear
I know. I haven't solved the tree for it. A few lines were literally dry rotted off of it. I don't know what is supposed to run where.
Old Jun 19, 2022 | 05:10 AM
tjc transport
i ain't rite
it really don't make a difference where what line off what port on the tree goes.. as long as you have a small line to the heat/ac controls, a large line to the booster, and a small line to the VRV if it has a C-6 all will be good.
Old Jun 22, 2022 | 10:35 PM
solanum's Avatar
solanum
The factory vacuum tubes on these were not particularly elegant anyway, don't stress over it. Just work some rubber line from each component back to the tree. If your truck has cruise control, that will need it too. The reservoir goes between the tree and the servo.
Dunno if this is helpful or not, but here's the info from my 1992, First Printing, service manual- which covers the early '92 V-belt system, which AFAIK is the same or extremely similar to an '88.
GavinL
Jul 26, 2021 09:38 AM
700hauler
Dec 4, 2014 12:37 AM
Orpackrat
18
Sep 7, 2013 08:04 PM
macius2004
Apr 4, 2005 06:02 PM
kman2785
Dec 13, 2002 10:01 PM
