Losing Antifreeze
Old Nov 9, 2003 | 06:10 PM
fordor's Avatar
fordor
Losing Antifreeze
95 F-150 5.0 liter
Recently I have noticed that my overflow bottle has been empty. I fill it up to the cold line , but two weeks later it's empty again. I see no leaks in the system (changed all the hoses and thermostat within the last six months.) My oil (just changed it) appears ok. Anyone have any suggestions where it might be going? When I start the truck it squeels if it's been sitting for a period of time. I'm wondering if my water pump is going bad. Temprature gauge is normal. Any thoughts?
Old Nov 9, 2003 | 06:53 PM
Talyn's Avatar
Talyn
MIght be leaking into the engine and burning off.
Check to see if oil is contaminated also.
Old Nov 9, 2003 | 08:53 PM
wrh's Avatar
wrh
Could be you water pump. If loses coolant that slowly you may have to wait till it gets worse before you can pinpoint the leak. Check the small hole by your water pump seal to see if it looks stained from leakage.
Old Nov 10, 2003 | 12:14 AM
mrwizard's Avatar
mrwizard
Can you smell antifreeze after you've been driving and shut it off? Get under the front and check carefully for leaks around the seams between the metal core and plastic end caps on the radiator.
Old Nov 10, 2003 | 09:16 AM
skp84's Avatar
skp84
I just replaced my radiator this past weekend. It started as a very slow leak between the core and the tank. I could only see fluid and smell it when I shut off the engine, and it was hidden behind the fan shroud. Needless to say when it decided to let go it went all at once...blew the tank gasket. Luckily for me it was in my driveway. And I never try to repair an aluminum and plastic radiator. It's much cheaper to replace it with a new one then to run the risk of overheating later and burning up the motor.
Old Nov 10, 2003 | 09:57 AM
forddytube's Avatar
forddytube
check you upper and lower intake especially around the the water port areas you'll probably see some build up indicating therers a leak, or is there coolant on the intake close to the injector s.
i had leaking upper intake and always smelt coolant vapors after driving and during.
Old Nov 10, 2003 | 08:39 PM
KeelarPluto's Avatar
KeelarPluto
If your hoses on your radiator are not secured tightly enough, the fluid will slowly evaporate....Also, If you filled your system and din't purge the air out, it could be still working the air out of the system perhaps.....
Old Nov 10, 2003 | 08:42 PM
Mike92f350's Avatar
Mike92f350
I recently experienced some loss of coolant, started out slow and was unnoticeable. Ended up being the water pump.
Old Nov 10, 2003 | 08:45 PM
KeelarPluto
Water pump has a weep hole that is basically a warning light of sorts that lets you know it's not working correctly.....
Old Nov 10, 2003 | 09:31 PM
dtpatt2's Avatar
dtpatt2
You got 10 or so ideas to check. Basically go over your whole entire cooling system piece by piece. check all hoses. Hope it's a hose and not a water pump. Normally with hoses though, it's very noticable(i.e. it burst)
vellingapa
Dec 28, 2013 04:26 AM
autofive
16
Aug 15, 2013 02:59 PM
MisterRanger
1983 - 2012 Ranger & B-Series
May 10, 2012 10:59 PM
SolidGround
Nov 14, 2007 07:52 AM
bkeese
Sep 5, 2006 10:34 AM
