2012 5.0 MPG
Old Jun 16, 2022 | 04:34 PM
mustang5o's Avatar
mustang5o
2012 5.0 MPG
I bought a low mileage 2012 FX4 with the 5.0L about 18 months ago. It had a little under 77K on it when I got it. Currently closing in on 90K. The MPG is only about 12.9 right now according to the computer display. It was only slightly higher in the first 17 months in the 13's. Is that normal MPG for this truck? Just starting research on the new F150 3.5 Hybrid. If it really gets 10MPG more I might be able to justify it.
Old Jun 16, 2022 | 04:46 PM
RLXXI's Avatar
RLXXI
Change the plugs, air filter, air up the tires, and disconnect the battery for no less than 15 mins to reset the KAM. That'll put the truck back into learning mode and will adjust to your driving nuances as opposed to the previous owners.
Old Jun 16, 2022 | 05:03 PM
mustang5o's Avatar
mustang5o
Thanks for the ideas. All of those have been done except for the plugs.
Best case scenario, what type of mileage should I expect or is possible. I drive pretty conservatively most of the time with a mix of interstate/city. Though most of my drives are short so I think that might be part of the issue.
Old Jun 16, 2022 | 05:08 PM
RLXXI's Avatar
RLXXI
I was getting 22mpg hwy when I got my 13 new, 19 around town or something close to that. I was able to bump that even higher with a custom tune from 5* tuning and was able to achieve 25 mpg hwy. All flat land near sea level.
If the tires have been changed from oem in size, that can make a huge difference in mpg as I found out when I lifted my truck 4" and put 35's on it. I don't give a rats *** about fuel economy, it's a truck. So I got another more aggressive custom tune from MPT and now run E 85 exclusively. Fun as hell to drive but 9mpg is about the best I get around town.
I'll get my mpg back when I buy an electric truck.
Old Jun 16, 2022 | 06:03 PM
newfordy's Avatar
newfordy
duplicated post
Old Jun 16, 2022 | 06:05 PM
newfordy's Avatar
newfordy
My '14, 5.0, 4wd, SCrew @ 180K, gets about 13 in town and about 19-22 highway. Unmodified. According to the trip computer.
I do keep the bed about 1/4 full with stuff.
Old Jun 16, 2022 | 07:09 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
mustang5o...
In addition to RLXXI's maintenance suggestions...
  • Clean the MAF sensor.
  • Insure that the tires are inflated to the recommended PSI.
  • Remove an unnecessary cabin and/or bed weight.
  • Reduce/eliminate use of tow/haul mode. *unless towing.
  • Check the condition of the front-end suspension components. *Repair if neccesary. How's the alignment?
... according to the computer display...
That's SWAG (Scientific Wild *** Guessing). Need to do real-world miles per gallon calculations - actual miles and gallons pumped.
Old Jun 18, 2022 | 09:19 AM
newfordy's Avatar
newfordy
.[/QUOTE]
I did. A couple of times. . . . within 1/2 mpg compared to dash display.
Old Jun 18, 2022 | 09:24 PM
Big_Al59's Avatar
Big_Al59
I have a 2013 5l super crew with 75k. It will average 16 mpg.
Bone stock.
Old Jun 19, 2022 | 09:14 AM
gDMJoe's Avatar
gDMJoe
Cool
F350 1990...
This is a F-150 forum, not a political soapbox, without (until your post) a reference to Biden / Trump.
But hey!... I once saw Dwight D. Eisenhower. He liked Cadillacs.
All of which has nothing to do with ...
2009 - 2014 F150
Old Jun 19, 2022 | 11:59 AM
mustang5o's Avatar
mustang5o
I didn't use to care so much about the truck MPG but with gas prices and the fact that it seems to have taken a 1MPG drop out of nowhere makes me more interested. I mean the truck is my daily though that duty gets shares during good weather with a 19 Mustang. The truck is also used to tow said Mustang to the track. When towing I had been getting right around 10MPG flat. Acceptable I figured. Just not happy to see this truck drop almost to what my old F250 V10 was getting.
Old Jun 28, 2022 | 01:09 PM
Bluez2013's Avatar
Bluez2013
2013 F150 5.0
I have 168,xxx miles on freeway roughly 20ish and about 14 city. I bought truck Dec 21. Bone stock. I have only replaced throttle body.
Old Jun 28, 2022 | 01:22 PM
mustang5o's Avatar
mustang5o
Now sitting under 12MPG. I might have to look at changing plugs or something. It seems to be running fine.
Jonesy0027
2015 - 2020 F150
Nov 13, 2019 06:08 PM
Jonesy0027
2015 - 2020 F150
45
May 19, 2019 08:10 PM
bigblue56
2009 - 2014 F150
Sep 14, 2017 06:24 AM
hsfbfan
2015 - 2020 F150
May 27, 2015 04:35 AM
elemint
2015 - 2020 F150
Feb 25, 2014 02:09 PM
