Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
compressed air?
Old Nov 9, 2003 | 05:31 PM
Vanhecht's Avatar
Vanhecht
compressed air?
what actually happens to air when it becomes compressed?
Old Nov 9, 2003 | 05:43 PM
kennyrrt's Avatar
kennyrrt
The molecules get pushed closer together so there are more airs in a given volume. The pressure is actually how hard they hit the sides of the enclosure. They don't like being so close and try to achieve some distance. The closer they are the harder they fight . <-----like him
Old Nov 9, 2003 | 05:53 PM
Stingray42's Avatar
Stingray42
This is a bunch of compressed air.
Old Nov 9, 2003 | 08:59 PM
BeSee's Avatar
BeSee
Re: compressed air?
When I compress air it is usually to hook up to my grinder, or my spray gun, or my air wrench, or my nail guns, or to fill up my tires, or to clean out the shop.
Thats what happens to it at my house.
Bill in Miami.
Old Nov 9, 2003 | 09:11 PM
oldroady's Avatar
oldroady
nother thought. when air is accelerated, the molecules actually space apart, reducing pressure.
Old Nov 9, 2003 | 10:04 PM
MisterCMK's Avatar
MisterCMK
And, when you compress the molecules, it creates heat, but then when you decompress them, it cools down.
Old Nov 10, 2003 | 01:00 AM
Vanhecht's Avatar
Vanhecht
now why the buildup of water in air compressers at the bottom when you have to empty it? are air molecules broken up?
Old Nov 10, 2003 | 02:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
No, the air molecules are not broken up. There is moisture in the form of water vapor in the air that condenses on the inside of your tank when the air is pumped into your tank. You can find all kinds of info on air compressors and systems in the Garage forum by using the search function.
Old Nov 11, 2003 | 10:35 AM
dfisher1's Avatar
dfisher1
All,
The truth is, that you don't create heat while compressing air. More truefully, the heat that occupied one cubic foot now occupies one cubic inch. Of course there is heat from the motor driving the compressor and there are heat gains from friction, but you do not create heat.
Air and water share a happy medium at atomspheric pressure. That is not true at 120 psi. Water vapor is forced to its liquid phase and ,ergo, you have condensation. If we could maintain the initial compressed air temperature, the water vapor would mostly stay in a vaporous phase but compressed air starts to reject its heat to the atomshpere immediately and a cooling effect drives the compressed water vapor to liquid.
I hope this help?
KingFisher
Old Nov 11, 2003 | 12:32 PM
kennyrrt's Avatar
kennyrrt
Gee,
Gas physics is my bag and I'm learning a lot, thanks guys
