2022+ F-150 Lightning EV Electric 1/2-ton - Ford's all-electric F-150 has arrived!
Ike Gauntlet test
Old Jun 15, 2022 | 06:11 AM
Split rims's Avatar
Split rims
Ike Gauntlet test
Old Jun 15, 2022 | 11:28 AM
WXboy's Avatar
WXboy
So towing uphill the effective range would be 40 miles at max capacity. That's with the extended battery too.
I wonder what that would be in normal but hilly terrain? Typical roads around the Rocky or Appalachian mountains where you're up hills and down hills and up hills the entire trip? Could you make it 80 miles? 100 miles? Anxious to see the future testing they're doing.
Old Jun 16, 2022 | 10:33 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hopefully they run Boulder to Ike or Boulder to Laramie and back to judge the realistic range.
Old Jun 16, 2022 | 02:23 PM
johndeerefarmer's Avatar
johndeerefarmer
With a bed full of batteries it could tow farther but then would have no payload. Electric vehicles and towing don't go together- at least not the current ones.
Did you see the .45kWh rate at the charging station? EV's aren't practical at those rates..
Old Jun 16, 2022 | 03:47 PM
twobelugas's Avatar
twobelugas
The gas/hybrid crew cab they used back to back has a 26 gallon tank and got 3.9 mpg up hill so figure about 100 miles of uphill range with the same load ona full tank, or 80 if one never runs below 1/5 of a tank.
with rolling hills both would recuperate some range with regenerative braking.
Old Jun 20, 2022 | 02:07 PM
Dim Sum's Avatar
Dim Sum
Originally Posted by twobelugas
The gas/hybrid crew cab they used back to back has a 26 gallon tank .
I think its 30.6.....26 gallons are the GM twins.
Old Jun 20, 2022 | 09:50 PM
twobelugas's Avatar
twobelugas
you are correct, the hybrid f150 has a 30.6g tank, 26 is listed as for the gas only ones.
So figure about 120 miles all uphill nonstop.
bigjake6
Nov 13, 2001 10:15 PM
