Bad servo?
Old Jun 14, 2022 | 10:08 PM
78Custom302's Avatar
78Custom302
Bad servo?
I just installed new brake lines, new combination valve, calipers, rotors, and rear brake shoes. I've bled the brakes, MC, and the combination valve-with that special tool. I have a very firm pedal w/o engine running. Rear brakes are adjusted so that the pads are lightly rubbing.
When the engine is running, the pedal goes the the floor. Vacuum leak? Bad servo? Super frustrated....
Old Jun 15, 2022 | 01:59 PM
meangreen92's Avatar
meangreen92
I think that is going to be a bad power brake booster/servo.
Sometimes when that happens with the brakes applying themselves, the internally leaking vacuum in the booster can actually suck brake fluid through the master cylinder's rear seal, and into the engine - which then makes the engine run like crap.
Adam over at Rare Classic Cars & Automotive History on youtube had this problem on an early-or-mid '70s full size Mercury. I'm hoping he'll revisit that car when it's repaired, and confirm or rule out my diagnosis.
Old Jun 18, 2022 | 07:03 AM
78Custom302
I figured it out. I just needed to adjust the rear drum brakes (front are disc) until the tires would barely turn. It was as simple as that. I hope this helps someone else.
Jpmxrider489
May 15, 2021 06:39 PM
Fords412
16
Nov 17, 2016 02:31 PM
rcnease
Sep 20, 2015 02:46 PM
79F150400M
Jun 19, 2012 07:55 PM
1979BEAST
24
Apr 28, 2011 07:57 PM
