good news i found why the truck was throwing all the new codes and going into reduced engine......... the darn connector came undone at the air intake tube. i recently changed the air filter and i guess the connector wasn't clipped fully and vibrated out. the nox sensor code came back but the others didnt and it started regen like it should......
now to research the nox sensor to see what part number it is to start the hunt......
thanks-
i am searching now for which nox sensors there are and to determine the upstream one to start my search- just slowly sifting thru nonsense to find them......
