Problem with changing park brake cables
Old Jun 13, 2022 | 02:35 PM
mowagman's Avatar
mowagman
Hi,
needed to change the rear parking brake cables on my 1992 E350 motorhome. Replacement parts have identical length as the old ones. But somehow they are still too short. I am missing about 7-10 cm for the connection to the front cable. If I pull them hard to connect them to the front, the rear brake is blocked completely. So I wonder if the park brake pedal has some kind of slack adjuster in it? Maybe some kind of spring spiral that rolled up and took away the now missing centimeters?
Thanks for your hints in advance, before I pull apart the pedal.
Regards, Florian
Old Jun 14, 2022 | 07:45 AM
DukeBerle's Avatar
DukeBerle
3rd Gear
Have you loosened the adjuster/equalizer where the 2 cables connect into the one cable to the parking brake pedal?
Old Jun 15, 2022 | 09:47 AM
tecgod13's Avatar
tecgod13
There is an adjuster in the pedal I think in the 92+ trucks, I don't know if it applies to the vans as well. Ford had issues with the adjuster, and issued a plastic locking piece that is inserted after the pedal has been adjusted. You need to remove that piece before it will loosen up. Then you can just magically pull the cable to get the extra you use.
Its a crap system, I can't get it adjusted right on my truck since I replaced the cable.
Old Jun 16, 2022 | 03:22 PM
mowagman's Avatar
mowagman
Ok, thanks. Yes, I have loosened the adjuster. This is how it looks like at the moment;
Brakes went up in flames on holiday last year. We came home as a trailer queen:
So now I am trying to get it all in order before our next vacation starts....
Best regards
Florian
Old Jun 19, 2022 | 05:19 AM
mowagman's Avatar
mowagman
Does not look like there is anything to adjust at the pedal:
Demounted the new cable passenger side again and checked again: same length:
I do not understand this. I am thinking about shortening the spiral spring at the end of the cable
KoreanFord
May 19, 2023 04:07 PM
msnrasool1
Jul 3, 2018 11:53 AM
andydunks
Jun 5, 2014 08:30 PM
meck1
1983 - 2012 Ranger & B-Series
Oct 14, 2010 10:58 AM
smokestone52
May 24, 2007 04:06 AM
