Volare front clip
Old Jun 12, 2022 | 01:11 PM
butchd88's Avatar
butchd88
Trailering
Volare front clip
Will a 15x8 wheel with a 4.25 backspace and -6 offset fit under the front of a Volare clip? 1956
Thanks
Old Jun 12, 2022 | 02:21 PM
gerrymoe's Avatar
gerrymoe
I had a 56 with the volare, I had 15x8 4 1/4 backspace, it worked but was tight on the brake caliper, I believe the -6 offset you are talking about must be with the tire mounted. I was running 70 series tires do not remember the size. On my panel which has the Volare I have 16x7 with 4" back space, 225/60R16 Goodyear tires. A -5 offset with this setup, if I aam correct on what the offset is. In your case I would say you are fine, the tire will be pretty close to your steering pitman arm. I went with 16's because they fill the wheel well better.
Old Jun 12, 2022 | 04:04 PM
butchd88's Avatar
butchd88
Trailering
If I went with a 15x8 with a 4 inch backspace It should be good, correct? The tire is a 225/70-15
Old Jun 12, 2022 | 05:22 PM
gerrymoe's Avatar
gerrymoe
I would say you are good to go
Old Jun 12, 2022 | 05:37 PM
butchd88's Avatar
butchd88
Trailering
Thank you for the info. I will give it a try.
FoMoCo13
Oct 26, 2016 04:45 PM
lexcoe
15
Feb 1, 2012 08:20 AM
paw_paw
Jun 12, 2011 08:11 PM
xumeng12
Mar 20, 2011 06:30 AM
fergusonicford
Nov 17, 2006 06:38 AM
