Uneven Radiator Support Spacing
The support in this truck was clearly original, yet the number of washers between the left and right rail were considerably different. The entire 'look' of the truck when together was fine. The modern rubber bushings and spacers from Carpenter make no allowance for individual stacking of washers. It's more like a solid tube. I could always source washers and replace the Carpenter tube with them to get it back to the original. Really more curious than anything.
I only have a pic of the passenger side rail below. But imagine the driver side rail having a stack of washers about half what you see here. The total difference between the two was 1/4". Maybe it was just sloppiness by someone on the assembly line.
as for me, i guess I just have to leave this stuff all loose as I build it back up and then figure something out on the fly if one side ends up looking lower than the other. I had assumed the issue would be coming from uneven rails, but that doesn't really make sense given their design and i'm sure jigs. your sheet metal assumption does however, given the gauge. thanks.
