Sponsored by: Auxito
Scwap Yard Finds
Old Jun 12, 2022 | 11:06 AM
Diesel my wonderful pit's Avatar
2nd Gear
Scwap Yard Finds
Hi everyone,
recently got a 2001 f150 4x4 automatic truck I believe 248,567 miles. Doesn't matter if it is at start up, park , neutral. Usually always a very noticeable tapping, ticking noise is heard . I was told to check tappets for looseness. Check torque converter possibly loose bolt. And also told head gasket is blown because of water dripping from rear exhaust. I'm not a mechanic and dislike working on the scary unknown lol.
Getting ready to go to garage and start truck and try to pen point issue. Any suggestions would be appreciated and comments about water dripping from exhaust explained would be great as well.
Thanks everyone 👀
2001 f150 4x4 automatic 248,567 miles Runs and drives great. Gear shift needs adjusted and noise is irritating also noise does seem to disappear only when accelerator is accelerating.
this is only way I can figure out how to say thank You! For information!!! I can't believe that guy pulled that blown gasket on me. How embarrassing . Condensation , thank You I will never forget that from this day on. I was told it had new or rebuilt transmission in it. That's why he thinks something loose. After my Aventura underneath, I have no catalitc converters and alot of Frankenstein welds with many many pieces of pipe dual exhaust . I seen one missing bolt on front drive axel and think I have hopefully the skills set to check torque converter. Quick question I turn engine over with nut on front crank shaft? Does it matter if truck is in park? Neutral?
Thanks again for helping me out.
Last edited by Diesel my wonderful pit; Jun 13, 2022 at 08:29 AM. Reason: I can't reply to say thank you to the man that answer my question question
Old Jun 12, 2022 | 02:02 PM
Jon Freeman's Avatar
Jon Freeman
Water from exhaust is usually condensation, not unusual.
The tapping/ticking noise is the concern. Indicates a mechanical problem that should be diagnosed as soon as possible. If you're not mechanically inclined, then the most efficient solution is to take it into a reputable shop and have them do a diagnostic and give you an estimate for the fix. Once the problem is identified then you can decide if repair work is within your skill level or have a shop fix it.
Firefighter 1406
Oct 27, 2016 03:23 AM
yuskoholic
1997 - 2003 F150
Dec 10, 2011 10:53 AM
mattyg
Aug 10, 2007 08:32 PM
Michael Littman
Apr 8, 2004 07:46 PM
