Weak Spark Conundrum
Old Jun 17, 2022 | 07:21 AM
rangerottis's Avatar
rangerottis
Update!
Ignition Control Module came in and I finally got a chance to install it. The truck now runs much better. Not perfect, but better. I've got some vacuum leaks to chase down and I've got a sneaking suspicion that the injectors may be sticking open, but I need to obtain a fuel pressure gauge to check that. So in conclusion, ICM's do not always completely fail, they can just cause a weak spark.
Old Jun 17, 2022 | 07:39 AM
Max Capacity's Avatar
Max Capacity
Maybe a can of can of this in the gas tank will help clean the fuel system. I split a couple of cans each Fall in my tanks.
http://Berryman Products 0116 B-12 C... (Single Unit)
Old Jun 17, 2022 | 08:45 AM
rangerottis
I might, but I'm still gone replace the single hole injectors with newer style 4 hole.
Old Jun 17, 2022 | 09:33 AM
Max Capacity
Another thing to think about would be to put a new fuel filter in the reservoir under the cab. I replaced mine when I could feel the truck starve for fuel while driving. I bought a new housing as mine cracked while unbolting from the frame rail. I used a chain wrench to rotate the cap off it. If you can spin the cap off, NAPA has a great filter for about $12.00.
There are a few small things you can do to help it run better.
Old Jun 17, 2022 | 04:09 PM
rangerottis
Mine has an inline filter, not a reservoir. I've replaced it once, but intend to again. We put a new pump in the tank, and I think that may have stirred up some trash.
irishredcoat
78
Feb 22, 2016 03:30 PM
pilotony
Aug 25, 2015 07:56 PM
WillInTheWoods84
Jul 27, 2014 04:25 PM
pro98
Aug 4, 2009 03:35 PM
