Help with window mechanism
Old Jun 11, 2022 | 01:57 PM
ynot321AB1's Avatar
ynot321AB1
'50 F-1, I have taken all of the screws out of the door and I cannot get the mechanism out. The handle is off but there appears to be something holding it in place. Suggestions would be apricated. It is broke and useless so damage is not a problem
Old Jun 11, 2022 | 05:17 PM
Bob Ingram's Avatar
Bob Ingram
Well that sucks. Did you disconnect the window from the regulator? There's only a few screws holding the regulator in. Often folks sprayed undercoating into the door, perhaps something like that it holding it.
Old Jun 12, 2022 | 08:39 AM
ynot321AB1's Avatar
ynot321AB1
Window is not even in the vehicle. The regulator is broken where the crank goes into the mechanism. I looks like someone forced it and broke everything. I have a replacement if I can get this one out.
Old Jun 12, 2022 | 11:09 AM
Bob Ingram's Avatar
Bob Ingram
Did you take the door latch mechanism out? The window regulator and latch mech are very close together and can interfere with each other.
Old Jun 12, 2022 | 12:08 PM
ynot321AB1's Avatar
ynot321AB1
Not hadn't taken it out but will check it out, thankls for the information
Old Jun 12, 2022 | 02:28 PM
1949f1's Avatar
1949f1
The window regulator is tuff to remove and it will only come out in one position and the door latch has got to come out first. I went through this too so be patient.
J2H
17
Jul 7, 2024 07:48 PM
hutchie
Jan 16, 2011 02:13 PM
timellis
Aerostar
Dec 20, 2010 07:21 PM
