Undercoating question
Old Jun 11, 2022 | 01:28 PM
Tugboatguy's Avatar
Tugboatguy
I got a new to me 2018 F150 XLT scab with 31,000 miles on it. I’m wondering about undercoating. I live in western NY so they do salt roads in winter. I drive my f250 for 6 yrs without undercoating it.
Should I get it undercoated? Their are 2 places that do it.
One is Krown. They use a product that will drop off for a day or 2. It needs to be reapplied every year at an additional fee.
The other is Ziebart which uses a wax type I think. It costs more upfront, but yearly touch ups are covered.
Unsure what to do. I think my truck has a fair amount of aluminum in it.
Thanks for any inputs you gents may have.
Old Jun 11, 2022 | 01:42 PM
fordman19762003's Avatar
fordman19762003
I just use Fluid Film and apply it myself. I've been using it since 2012(multiple vehicles)and it's worked great, only negative is it turns the underside of you vehicle into a grimy mess.
Old Jun 13, 2022 | 07:54 AM
jake415's Avatar
jake415
I took my truck to Krown. I think the product is good, but leaves a drippy mess on the floor for a couple weeks. I drove it down some dusty gravel roads so the dust would stick to it and cake it up to stop the dripping. Thus the "grimy mess" the post above me mentions.
Not happy the tech that sprayed my truck didn't know how to remove my tail lights and broke the mounting tabs off the first one he removed. Of course he just put it back together without telling me. I found out when my tail light started falling out a couple weeks later. So the cost of the undercoat also included a new tail light for an additional $85. The B.L.I.S. tail lights were $700 last time I checked, so the potential is there for this job to cost far more than the price of the undercoating.
So lesson learned. My new M.O. is do anything and everything yourself if at all possible.
Old Jun 13, 2022 | 09:04 AM
JKBrad's Avatar
JKBrad
No need to coat the under body, as it's a coated aluminum. The frame could use it, especially inside, as it's fully boxed steel. Suspension and axles if you don't like seeing surface rust.
Old Jun 13, 2022 | 09:08 AM
Olds64's Avatar
Olds64
^^^THIS^^^
I use Fluid Film on my Oldsmobile where I scrapped the paint off to ground my mobile ham radio. It's been over a year and there isn't a hint of rust. Of course, winters aren't that cold in OK so I don't have to worry about applying it to the underside. It's available online:
Amazon Amazon
Old Jun 13, 2022 | 08:54 PM
Bent6's Avatar
Bent6
Personally I thing that Fluid Film smells awful for a week or two, and doesn't hold up well to direct spray. I believe pb blaster surface shield smells much better, like cedar, and seems more durable. As for me I sprayed my underside with Boiled Linseed Oil.
Old Jun 19, 2022 | 08:26 AM
F350 1990's Avatar
F350 1990
All the "rubberized" undercoatings do is provide entrapment points for moisture which actually accelerates rust.
Old Jun 23, 2022 | 01:39 AM
Stealth13777's Avatar
Stealth13777
Fluid film or similar on/in the frame and axle. Leave the aluminum body alone.
Ford did the entire body in aluminum. They’re the only ones so far. The bed in its entirety, cab, doors, fenders, hood - it’s all aluminum. The frame and suspension are still steel.
Old Jun 24, 2022 | 02:49 PM
bbender85's Avatar
bbender85
here in salty michigan i had a lifted first-gen superduty that i spent a whole weekend wire wheeling and brushing the frame and axles shortly after i got it, then just sprayed with the cheapest flat or satin black rattle cans of paint i could find; every spring i'd just just touch up spots with a wire wheel and apply again. cheap, and always looked fresh.
1oldtimer.foc
Dec 3, 2021 09:08 AM
purplewg
21
Jun 9, 2016 02:55 PM
Patrick R.
General Automotive Discussion
Apr 29, 2016 04:10 PM
brad93f150
Apr 30, 2003 10:22 AM
