Front end clunk
Old Jun 11, 2022 | 12:25 PM
TEEJAY's Avatar
TEEJAY
Front end clunk
2015 4x4 with 100k. Every once in a while when the steering is all the way to the right I get a 'clunk'or 'pop' from the driver's side front end.
Tie rods, ball joints and sway bar links are tight. I thinking CV shaft because it only happens when I'm moving. Anything I am overlooking before replacing the shaft? TIA
Old Jun 11, 2022 | 01:53 PM
scott91370's Avatar
scott91370
When you say tight do you mean the nut holding them is tight or there is no play in any of them from the ball/socket area?
You should be able to grab the axle shaft and see if it has movement as well. Do it with th wheels straight and turned each way.
Old Jun 12, 2022 | 09:51 AM
TEEJAY's Avatar
TEEJAY
When checking ball joints, I always support the lower control arm and pry up on the tire with a large bar.
No movement in either ball joint or tie rod.
Old Jun 14, 2022 | 04:21 PM
itsbronyo's Avatar
itsbronyo
1st Gear
I have a '16 2.7 4x4 135k
At work we have a wash out at the edge of the asphalt where our gravel parking lot starts. I too have noticed a good little clunk at full right lock once the truck falls into the gravel wash.
Everything seems solid, my only remedy is to swing a little wider and avoid turning it to full lock. Also this happens at or around walking speed, and has also happened way more than once.
Old Jun 17, 2022 | 03:34 PM
TEEJAY's Avatar
TEEJAY
Confirmed the noise is coming from the driveline, not front end. Talked to the dealer today and going to be difficult to pinpoint because it is intermittent.
Old Jun 17, 2022 | 03:54 PM
JKBrad's Avatar
JKBrad
Grease the output splines for your driveshaft. Easy to do and often times that's the issue. Also, I've never heard of a motor mount going bad in these trucks but it might be worth a look.
steelandspeed
Sep 6, 2019 05:04 PM
troverman
Oct 25, 2016 10:15 AM
NBT22555
Jun 4, 2014 05:18 PM
clintonvillian
2004 - 2008 F150
Jan 22, 2014 12:46 PM
rtazz17
Jun 21, 2009 08:22 PM
