My truck will not remain in first gear. It will shift into it (while running) but as soon as you try to drive it, it will pop out. Any Ideas? I bellieve it is the Clark 4 speed OD.
I have removed the inspection plate, and found that all the gears looked fine... however, I noticed that the upper shaft and gear assembly all move when shifting it into first.
