Somethings wrong...
Old Jun 9, 2022 | 03:37 PM
ks4722's Avatar
ks4722
Somethings wrong...
I towed with my truck at 400 miles and didn't wait the full 1000 and I think I screwed something up... my gas mileage has been HORRIBLE, there's no way this truck should only get 300 miles a tank city driving, right?
Old Jun 9, 2022 | 03:54 PM
Bruin78's Avatar
Bruin78
DTE resets on each fill up based on recent MPG from current driving habits. So if you just towed and we’re getting 8mpg and have a 36 gallon tank it would display approx 300 gallons (288 if exact) to empty. DTE will increase after you drive a with a few tanks not towing.
CheeseheadFord's Avatar
CheeseheadFord
Depends on your foot, if you're doing 80% city driving I could see that being the case. Anything other than highway driving I see single digit MPG on my dash with my 7.3. Assuming you have the 35 gallon tank, 300 miles per tank is 8.5ish MPG, not unheard of driving a brick through stop and go traffic. Towing before the 1k miles did nothing to affect your MPG you're seeing now.
BillyE's Avatar
BillyE
What is your MPG when you're not towing, and what is the engine/configuration?
Old Jun 9, 2022 | 03:55 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Need more info, what truck exactly.
What are we supposed to be looking at in that pic???
Old Jun 9, 2022 | 03:56 PM
dyhrdford's Avatar
dyhrdford
I doubt not waiting for the break in period before towing has any effect on your mileage concern. I've read the break in is mainly for the differential.
Have you been towing a fair amount recently? Have you tried resetting the fuel economy "tracker"?
Old Jun 9, 2022 | 04:01 PM
1olddogtwo's Avatar
1olddogtwo
It's toast, it's ingrained to the PCM.
You knew not to tow before a 1000 miles.......
Kidding, just relax the computer will adjust over time.
It's not uncommon for my truck to be down to 3 mpg for 100's miles at time. When I drop a trailer, it takes some time for the computer to reset itself.
Old Jun 9, 2022 | 04:20 PM
last5oh_302's Avatar
last5oh_302
Obviously when towing your mileage goes down because of it, but when I'm empty and reset the computer after filling up the truck it gives me how many miles until empty based on the previous mileage. That number (miles until empty) actually goes up as I drive the truck empty since the empty mileage is better..
Old Jun 9, 2022 | 07:02 PM
RidgwaySD's Avatar
RidgwaySD
Did you check to make sure the front hubs are set to AUTO not LOCK? Lots of trucks delivered locked and it knocks mpg down by 1-2 depending. No way towing before 1000 miles has anything to do with your mileage.
Old Jun 9, 2022 | 07:49 PM
traveldawg's Avatar
traveldawg
On my 2018 I can select DTE calculated for towing or not towing. So the DTE can vary. And I can also reset it at any time so it starts over again.
Like others said... if you just towed then the DTE is going to reflect the MPG (and, therefore DTE) based on your towing fuel consumption.
BlankSpace
Nov 11, 2020 10:11 PM
speakerfritz
Nov 11, 2020 07:38 PM
Christof13T
Sep 21, 2012 09:22 PM
bronco28806
Bronco II
20
Aug 23, 2006 11:32 PM
Slammer12
Escape & Escape Hybrid
33
Feb 18, 2005 09:19 AM
