Just installed 35's
Old Jun 8, 2022 | 03:27 PM
jimzpsd's Avatar
jimzpsd
Just installed 35's
Is it really necessary to go into Forscan and change my tire size? Or is the speedo not that far off? TIA
Old Jun 8, 2022 | 03:30 PM
4wd6.7L's Avatar
4wd6.7L
Up to you. I can't imagine it being too far off, if at all. I would check it against a GPS or something. Who knows, the truck could be off a bit with the factory size.
Old Jun 8, 2022 | 03:35 PM
jimzpsd's Avatar
jimzpsd
I mainly want an accurate "miles to empty" quote
Old Jun 8, 2022 | 03:51 PM
4wd6.7L's Avatar
4wd6.7L
It's questionable how accurate the DTE actually is to begin with. If you are concerned, which it sounds like you are, then change it in Forscan. My opinion is that the difference in tire size is minor (unless you had 33's) and won't make much difference, if any. Also dependant on how accurate the truck is to begin with.
Old Jun 8, 2022 | 03:52 PM
OverheadCram's Avatar
OverheadCram
I would verify it against a GPS or traffic speed monitor. Every SuperDuty ive purchased since 2009 has been off roughly 3% from the factory.
Old Jun 8, 2022 | 04:41 PM
GreenToxon's Avatar
GreenToxon
Trailering
I went to 35s from the stock 31s. I think the speedo is about 10% off for me according to my phone GPS speed when driving and comparing.
What was your previous tire size?
Old Jun 8, 2022 | 04:47 PM
Blackhawk23's Avatar
Blackhawk23
Trailering
Why would you want to? Keep the smaller tires in the system, odometer will read out less than the truck has actually traveled, better for resale.
Old Jun 8, 2022 | 07:14 PM
jimzpsd's Avatar
jimzpsd
31's same as yours. With my old tires, my mte and mpg and speedo were very accurate according to the mathematics
Old Jun 8, 2022 | 07:20 PM
4wd6.7L's Avatar
4wd6.7L
Now that you have cleared that up....31's to 35's is a pretty big jump. My other truck came from the factory with 31's. I swapped to 33's and the 1-2 mph discrepancy never bothered me, but I bet 31 -35's would be enough to make me want to correct it.
Old Jun 8, 2022 | 08:11 PM
jimzpsd's Avatar
jimzpsd
I cannot find a specific setting in the ForScan spread sheet for 35's, only 37's..........how would I go about this ?
Old Jun 8, 2022 | 08:14 PM
jimzpsd's Avatar
jimzpsd
I assumed most SD's came stock with 31's
Old Jun 8, 2022 | 10:56 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
In the ForScan sticky
ForScan Tire Calculator Thread
ZooDad
Old Jun 9, 2022 | 06:01 AM
jimzpsd's Avatar
jimzpsd
ZooDad
WOW, thank you very much
Old Jun 9, 2022 | 07:57 AM
Pugga's Avatar
Pugga
Depends on the trim level, there are several different overall tire sizes that came stock on the 4x4 SD ranging from 31" to 34". It's not necessary to reset the truck using ForScan, it's just a matter of how much your speedo and ODO being off is going to bother you.
Old Jun 10, 2022 | 07:50 AM
jimzpsd's Avatar
jimzpsd
Thats part of my concern, .....my speedo will indicate 75 mph but the gps says I'm doing 81 mph. So in a 70 mph zone I'm going 11 mph over the limit and with my luck, I'll get the ticket lol
