Sponsored by: Real Truck
Dually tires
Old Jun 7, 2022 | 08:29 PM
264WSM's Avatar
264WSM
Dually tires
235/86/16 tires are getting in short supply. 265/75/16 is easier to get but seem to be too wide to run on the rear of a dually. I have seen guys run spacers (because they think it looks cool and want to shorten the life of their wheel bearings) and I want to avoid that if I can. If I can't what is needed to run 265/75/16 tires on the back. Keep in mind I don't want my tires to ever think about touching and I load the truck with 3K pounds regularly.
Old Jun 7, 2022 | 10:23 PM
Sparky04SD's Avatar
Sparky04SD
I have 265's on all 6 positions on my dually for the past year. I did away with the dually style front wheel hub and replaced the front hub with a standard SRW style and run a SRW 16" x 7" front wheel with a 265 tire. The rears are 16" x 6" with a 1.5" steel wheel spacer and two 265's on each side. Gives me about 1" space between tires. Has worked well for me over the past year. Before changing the front back to SRW style my tire wear was horrible on the front and since the change is very good. I tow a FW and carry 2700 regularly on the 5vr hitch.
Old Jun 8, 2022 | 09:35 AM
264WSM's Avatar
264WSM
Did you need to get longer lug studs to run that wide of a spacer?
Old Jun 8, 2022 | 11:58 AM
redford's Avatar
redford
FTE Leadership Emeritus
You might try ordering online, like maybe from Tire Rack. They seem to have dozens of Load Range E 235/85R16 tires in stock and ready for shipping.
Old Jun 8, 2022 | 11:02 PM
Sparky04SD's Avatar
Sparky04SD
No, no modifications are needed. You first put on the inner dual tire, then the spacer goes on over the inner tire and the lug nuts are tightened. then the outer dual tire and the next set of lug nuts. The spacer has a set of lug bolts on it that the second tire is bolted to. I have a little over 1" clearance for the 265 duals.
Old Jun 9, 2022 | 09:59 AM
264WSM's Avatar
264WSM
OK Thanx
VIrgin tires from Tire Rack (or anywhere else) are too expensive. I run remolds https://www.treadwright.com/collecti...CZxvTA#by-size
Old Jun 9, 2022 | 10:30 AM
redford's Avatar
redford
OK Thanx
I may have to look into those. How do they wear?
Old Jun 10, 2022 | 10:42 AM
264WSM's Avatar
264WSM
More aggressive tread wears quicker. Getting the walnut shells mixed in for traction causes quicker wear. I try to run the Dirt Lord/Axiom in the summer and the Claw in the winter. The Axiom/Dirt Lords wear like iron, The Claws kinda wear fast. Avoid the Wardens like the plague!! They are terrible in the snow and mud, OK in dirt. It helps to have an extra set of rims and run them seasonally. Even the Dirt Lords do good in snow up to 3" or so.
RockWVU
Mar 2, 2012 11:45 PM
craziejoker
Jun 26, 2007 10:05 PM
70T351W
Feb 23, 2007 10:51 PM
rhino1
Offroad & 4x4
24
Dec 11, 2006 11:14 PM
