1976 Dome Light Question
Old Jun 6, 2022 | 05:54 PM
Landman 454's Avatar
Landman 454
When I got my 76 Highboy a while back it had no Dome Light... just a wire hanging down with some black tape on it. I have replaced my door jam switches and the wire is hot when I open the door. I ordered a new Dome Light from Dennis Carpenter and it looks fine but I have no idea how to hook up the wire to it. It has no place to attach a wire and of course it did not come with any instructions. Is there some special connector that attaches to one of the 4 screws? It appears that the power should hook up to one of them.
Thanks
Old Jun 6, 2022 | 06:56 PM
440 sixpack's Avatar
440 sixpack
The hot wire hooks up to one side and the switch wire grounds it out.
Old Jun 6, 2022 | 07:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Jun 6, 2022 | 08:05 PM
John89's Avatar
John89
The power feed runs to the top right mounting screw. (See threaded connector)
If your wire is missing the connector, I would put a ring connector on it and drill a hole to feed it through the back of the housing to that top right mounting screw. Use the plastic housing to insulate it from the sheet metal.
Notice the upper right screw
Old Jun 6, 2022 | 09:38 PM
Landman 454
John89 I am missing that special connector. So if I understand.... I need to connect my wire to the top right screw on the dome light but protect it from touching the body somehow.? I’m assuming that special connector isn’t available anywhere.
Old Jun 6, 2022 | 10:34 PM
John89's Avatar
John89
It might be available, but I would just figure out a way to get a ring connector or spade connector under that screw.
You'll have to drill a hole in the back of the housing to get the wire inside. I would make it large enough for the connector to fit through as well.
The lower left hand screw is what grounds the circuit.
You might need to use a shim at that upper right location since you don't have the stock connector in place to keep the housing level.
Old Jun 7, 2022 | 05:05 AM
77&79F250's Avatar
77&79F250
$27 https://www.ebay.com/itm/29497986530...BoC2GgQAvD_BwE
$34 https://parts.ford.com/shop/en/us/wi...assy-6278697-1
Old Jun 7, 2022 | 09:55 AM
John89's Avatar
John89
After thinking on this a little more and looking at the links to the stock connector above, it may not be as easy as adding a ring or fork connector.
You may have to either get the stock connector (pricey) or use a plastic screw and a non-conductive backing plate at that one location.
Post a picture of the spot where the stock connector should be.
I fiddled with mine a little, but am afraid I will break it if I try to see how it attaches. My guess is that there is an open square for the stock connector to snap into.
Old Jun 7, 2022 | 12:39 PM
Landman 454
This is what it looks like... it’s a 76.
Old Jun 7, 2022 | 12:47 PM
Landman 454
I’m wondering if one of those on eBay that 77&79f250 posted might work.
Old Jun 7, 2022 | 12:52 PM
68Flareside240's Avatar
68Flareside240
The door jamb switch does not ground when open to close the circuit and illuminate. That’s on chevys. Power goes to the door jamb switch on a yellow/green stripe, and exits the switch on a black/blue to the dome light. It grounds to the body on a mounting screw. Fordification.net shows the circuit diagram in their technical articles. As for the connector, I am not sure I have not taken my down to look but can do that if you need me to.
Old Jun 7, 2022 | 03:19 PM
77&79F250's Avatar
77&79F250
Landman 454 PM send to get you just the elec connector you need. Reply and we can work out a deal for an OEM dome light elec conn.
Old Jun 7, 2022 | 06:02 PM
Landman 454
Thanks! That’s great!!!!
Old Jun 7, 2022 | 09:37 PM
Landman 454
77&79 I got your message and attempted to respond but not sure if I did it right. I don’t know if my message was sent to you.
Old Jun 7, 2022 | 09:47 PM
77&79F250's Avatar
77&79F250
You did it right, I received the PM. I will get you one out of a parts truck tomorrow and in the mail to you same day.
