clutch?
Old Jun 5, 2022 | 08:59 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
clutch?
Parked my truck over 6 years ago my clutch worked fine then, well now with new slave and master cylinder my clutch slips, I've fiddled with the push rod arm in different positions and I either have slip or no slip but when I have no slip I can't disengage to drop into 1st or reverse. any thoughts? Swapping the oem dual mass clutch seems eminent.
Old Jun 6, 2022 | 07:09 AM
Talyn's Avatar
Talyn
The DMF surface is awful, the DMF is awful.
The Brass wound Luk clutches are really good.
And also Valair is made in in the US and you can get a brass wound from them as well and a new flywheel.
Or you can get ... higher HP rated clutches from valair depending on what you need.
Old Jun 6, 2022 | 11:34 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Check that swing arm for full travel? Pedal box bushings?
Agree, the DMF will fail in short order on these. Mine even has an OASIS for it being done around 99/00. Which would have been around 60-70k I think. Luk SMF kit seems to be very popular and works well, mine had one when purchased. Nice unit. Any of the aftermarket units are a 13" disc too, stock is 12.25" I think.
Old Jun 6, 2022 | 07:58 PM
Jaaaaaaackman
Forgot to mention the pedal box bushings are new along with push rod and the link that the push rod attaches to also the master and slave cylinder are new , only thing left is the clutch/fly/pressure and a fork I just don't get how it could have gone bad while it was parked. Can you tell I don't want to pull down the tranny
Old Jun 6, 2022 | 09:46 PM
nomad221's Avatar
nomad221
All good info from the senior guys that posted above. If you plan on replacing your injectors for more HP, upgrade the plate.
Old Jun 7, 2022 | 05:50 AM
Talyn's Avatar
Talyn
throwout bearing most likely.
Old Jun 7, 2022 | 07:21 AM
Marfarama's Avatar
Marfarama
Originally Posted by Hit Man X
Pedal box bushings?
I had to do mine. Totally worn out. Weak design but cheap fix.
Old Jun 8, 2022 | 09:56 AM
helifixer's Avatar
helifixer
my son's '95 is the same way, due to time we just removed the master cylinder and put 2 flat washers between the master and the fire wall. some day we will do the hemi joint and remove the washers.
the master isn't returning far enough for the fluid to bleed back to the reservoir.
Old Jun 10, 2022 | 05:52 AM
Talyn's Avatar
Talyn
HAAAY buddy. =)
Yeah, Heim Joint so worth it.
I pulled my master and did it on the bench when I did mine.
Diesel wyatt
1983 - 2012 Ranger & B-Series
May 11, 2015 09:51 PM
300I6VAN85
Apr 17, 2007 09:42 AM
reddnnek
Feb 20, 2007 06:11 PM
drillerdan
Nov 15, 2004 08:51 AM
