chasing down a miss
Old Nov 9, 2003 | 12:52 PM
HiDesertRat's Avatar
HiDesertRat
chasing down a miss
For all you gutter heads, this is a miss in the engine; not a miss as in young lady!
I have a 460 which we just rebuilt and is seems to have a small miss during idle. I also noticed it when going down the road at normal speed.
In my searching, I removed one wire at a time to see if I could notice any differance in the idle of the engine. With this big engine, I wasn't able to really tell much of a differance, so decided to try two wires at a time. I just found it interesting that I could remove every other wire on the dist. cap and the thing would still run without much of a differance in the idle!
What is a good way to determine if one of the sparkplugs is not firing? I am thinking of removing four (everyother one) and than one at a time for the other four. Once that is done, remove the other four (every other one) and check the remaining ones. Just thought there may be an easier way. Getting tired of getting zapped by stray sparks from the dist. posts!
Old Nov 9, 2003 | 01:39 PM
locknkey's Avatar
locknkey
Use a Timing light on each plug...you'll find the miss easy.
Old Nov 9, 2003 | 01:58 PM
HiDesertRat
Talking
See there, I knew there was an easy way to do this! I am going to assume, if the miss is on that plug I will not have any light on the timing light. No current flow, no inductive pickup....no light.
Is it normal for this engine to run well on four plugs?
Old Nov 9, 2003 | 02:12 PM
plowpusher's Avatar
plowpusher
try loading it in gear with four plugs diconnectedthe killing part is normal check idle mix to ythat will show as aslow speed/idle miss to the best way to check pug wires is under load have a partner hold the brake stand off to the side and pull plug wires look for a vacum leak to
Old Nov 9, 2003 | 02:49 PM
locknkey's Avatar
locknkey
It will miss even while its in park with the motor rev up....its a real good way to find a bad plug or wire....
Old Nov 9, 2003 | 10:41 PM
motorheadmach1's Avatar
motorheadmach1
i had amiss in my 302 efi that i couldnt find doing an elimination test at idle because of how the motor ran. my service manager at work told me to put it in gear and put a little gas to it to put aload on the engine, thre was a big difference with every wire and one of them didnt make a diference at all. that was the miss. to check plugs just switch plugs out.
Old Nov 10, 2003 | 12:12 PM
HiDesertRat
Thanks guys, I should have the truck back in the yard later this week... the owner has it now. I will take a shot at the timing light method. It is a standard, so applying a load will be a bit more complicated, but I am sure we can do it...If I can trust the owner with clutch control!!!
I am beginning to think it may be a misadjusted carb. Is there any good method to adjusting the carb? It has a four barrel with two mixture screws at the base. I adjusted them by going back and forth until the engine sounded good, but maybe there is a better way. I seem to remember there was a way of doing this with a vac. meter hooked up, but can't find anything in the books I have. Any ideas here?
Old Nov 10, 2003 | 05:01 PM
allv8fords's Avatar
allv8fords
turn the mixtures all the way in.. then turn them 1 turn out.then start the truck.. do the left side first and turn out more about 1.5 turns out till it is runnning okthen do the right then set yer idle.. most carbs on equal psi cylinders will be about 1 to 2 turns out and are mostly 1.5 or so..
