Which side is which?
Old Jun 5, 2022 | 05:22 PM
Adam31478's Avatar
Adam31478
I'm upgrading my '65 F250 2wd from drums to dual piston caliper discs. I'm almost finished, but I'm stuck for the moment. Which one of these supports goes on the driver's side and which goes on the passenger side? Thanks.
Old Jun 5, 2022 | 06:56 PM
1browski's Avatar
1browski
What make/model/year do these brake parts come out of that you are swapping?
Old Jun 5, 2022 | 07:53 PM
Adam31478's Avatar
Adam31478
I am fairly certain that it's from a 1977 F250 Crewcab.
Old Jun 5, 2022 | 09:07 PM
ivsamhain's Avatar
ivsamhain
Can you see a difference? Pretty sure they are the same, look up the part.
Old Jun 6, 2022 | 12:12 PM
Adam31478's Avatar
Adam31478
I've looked up the parts in the MPC, shown below. It doesn't list right-side or left-side specifics, such as for the brake caliper support.
However, there appears to be a subtle difference between the two. One of the ends probably need to be at the top with the key (2B487) and spring.
Old Jun 6, 2022 | 01:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 when you bolt the caliper bracket to the caliper body, it needs to have the larger edge (that the caliper retaining key and spring are going to go against) to match up. I know on a 4wd that key is on the bottom, not sure about a 2wd.
Old Jun 6, 2022 | 01:32 PM
77&79F250's Avatar
77&79F250
Well did a comparison ck, these look to be able to be installed either way.
Old Jun 6, 2022 | 02:24 PM
Adam31478's Avatar
Adam31478
Thanks. Appreciate the help.
Old Jun 6, 2022 | 07:57 PM
Pickupmanx2's Avatar
Pickupmanx2
I was going to say that the brake lines are usually on the top IIRC... your mileage may vary.
Amphihauler
1966 - 1977 Early Broncos
Mar 14, 2022 11:16 PM
Motate455
15
Feb 11, 2019 08:43 AM
MtnDweller
Colorado Chapter
Dec 10, 2018 09:07 PM
applebaggins
May 19, 2018 01:33 PM
Nicktitan
May 3, 2017 03:28 PM
