'53 "Effie" suspension
Old Jun 4, 2022 | 08:18 AM
FINKSTR's Avatar
FINKSTR
4wd High
Fellow "EFFIE" Fans,
I'm in the process of doing a total restoration on my '53 F100. Fortunately, so far I've been able to find most most of the parts I need - but UN-fortunately not all. The engine and trans are done. The frame and suspension parts have been disassembled, sandblasted and "POR15-ed". So far, so good. Except... I was assembling the front suspension and noticed that both front spring hanger brackets - the ones riveted to the frame - are badly worn. It appears that these parts are no longer available. Any suggestions would be appreciated.
Oh... This is my first posting, so bear with me while I figure this out!
Thanks!
Old Jun 4, 2022 | 08:59 AM
56panelford's Avatar
56panelford
You'll need to source them from someone who's installed a IFS that has no need for them.
Old Jun 9, 2022 | 07:06 PM
56panelford
I checked the ones on the 56 F100 frame I'm going to scrap and they are oval shaped as well but wondered if you drilled yours out to a larger hole you might get away by inserting steel bushings..
Old Jun 9, 2022 | 07:23 PM
craftsmangary's Avatar
craftsmangary
I may have what you need and I'm just a few miles away
lomesome1
May 10, 2021 10:51 AM
fastphil
Apr 22, 2020 07:39 PM
hardway
May 4, 2007 04:07 AM
93rngr
Mar 31, 2002 12:34 PM
