Code P0455
Old Jun 11, 2022 | 07:39 AM
projectSHO89's Avatar
projectSHO89
The Mode $06 data can be confusing if you don't understand what you're looking at.
If your EVAP monitor shows as having cleared, your original concern is resolved. If it's still incomplete, just drive the truck normally until it eventually runs and you have a result. The monitor may take days or weeks or it could run the first time out.
Old Jun 11, 2022 | 10:10 AM
chzuck's Avatar
chzuck
Thanks. You have been a good coach!
Old Jul 4, 2022 | 01:35 PM
chzuck's Avatar
chzuck
Root cause found.
hose to filler neck vent.
Old Jul 4, 2022 | 01:41 PM
projectSHO89
Yeah, that would do it. Find that on a visual inspection or via a smoke test?
Critters chew it up or was it just the hose had rotted out?
Old Jul 4, 2022 | 03:39 PM
chzuck's Avatar
chzuck
Squirrels. Had it inspected and mechanic saw claw marks On tje gas tank. So i started looking from the passenger side wheel well and saw it. Probably need to pull the bed up some to access it.
Old Jul 4, 2022 | 04:04 PM
projectSHO89
Damned varmints!
At least you have a known issue (that would cause your fault) that can be fixed. You can either drop the tank or raise the bed to get to it. Or, for the real "redneck", cut a hole in the bed.
Old Sep 21, 2022 | 04:34 PM
chzuck's Avatar
chzuck
Update. Bed removed and line replaced. Should I clear the code or just wait until it clears itself?
FORScan says I have Secondary air system monitoring alarm: Not supported when running KOER test. Does that mean my truck does not have that function?
OBDwiz says $32 - EGR Monitor Bank 2 Fail
Old Sep 21, 2022 | 04:56 PM
projectSHO89
Reset it and allow to retest.
Ignore the OBDwiz stuff...
Old Sep 21, 2022 | 06:25 PM
chzuck's Avatar
chzuck
OK, will do.
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
