Thermostat problems
Old Jun 3, 2022 | 04:05 PM
moschops's Avatar
moschops
4wd Low
Thermostat problems
Good afternoon,
So we are still having some problems with the old girl. First off, we finally found out why there was oil in the coolant, we got a cracked block. We just threw some block sealer in it for now while we look around/save up for a replacement. Engine temp light is now on. We just replaced the water pump and the thermostat today. The coolant seems to be circulating threw the engine but not the radiator. Truck warms up just fine and doesn't over heat. When the radiator cap is opened, the coolant is still cool to the touch and doesn't seem to be moving into the engine
Old Jun 3, 2022 | 05:43 PM
Hit Man X's Avatar
Hit Man X
Check the oil cooler?
Old Jun 3, 2022 | 07:02 PM
moschops's Avatar
moschops
4wd Low
Oil cooler, gaskets and o rings are all brand new
Old Jun 7, 2022 | 07:10 AM
pern21db's Avatar
pern21db
Originally Posted by moschops
Good afternoon,
Thermostat get installed upside down by mistake?
Old Jun 8, 2022 | 05:27 PM
moschops's Avatar
moschops
4wd Low
Everything's been installed correctly
Old Jun 8, 2022 | 06:10 PM
helifixer's Avatar
helifixer
1) short stem or long stem thermostat installed?
2) is it a F6TZ8575EA motorcraft thermostat? (long stem) I will only install motorcraft thermostats in these engines, they have an air bleed hole, with out that it will airlock and never get hot enough to open.
3) did the water pump have a clear plastic cover on the impeller to protect it during shipping? if yes was it removed?
this thread seems like an addition to another thread, has the radiator been changed? if so was the shipping plugs removed from the inlet and outlet ports?
Odisvan
Jul 15, 2024 04:30 PM
JGreen236
Apr 14, 2020 07:52 AM
99F350bigorange
27
Dec 30, 2013 06:33 AM
rodeostar546
Nov 25, 2005 07:01 PM
'95 Splash 4.0V6
Jan 3, 2004 03:19 AM
