does no thermostat = a cool engine?
Old Dec 30, 2003 | 04:15 AM
'95 Splash 4.0V6's Avatar
'95 Splash 4.0V6
i may be crazy but if you bipassed your thermostat, wouldn't that keep your engine cool all of the time?
I mean all it really does is restrict flow of coolant until it reaches a certain temperature. If it just wasn't there, wouldn't your cooling system be circulating constantly
Any thoughts? If not, just slap me and tell me to shutup
Old Dec 30, 2003 | 08:19 AM
Steve91's Avatar
Steve91
In a lot of applications the thermostat serves two functions. It allows the coolant to go to the radiator, and it also blocks a bypass port to prevent the coolant from constantly recirculating back into the engine. That is the case with the 4.0L.
Old Dec 30, 2003 | 08:52 AM
hyepwrd's Avatar
hyepwrd
coolant is going to be circulated either way, and the resistance by the thermostat isn't significant.
if you dont mind it taking forever for the engine to warm up (on those frost filled mornings) go for it. your engine should be cool with a thermostat as well as without (no difference). if there is a difference, it means you have other problems.
its good to ask questions. its how you learn. i pity those who dont and 'trust' their mechanics
Old Dec 30, 2003 | 03:08 PM
MrBSS's Avatar
MrBSS
Actually, your engine would probably be too cold most of the time. Engines are designed to operate at a certain temperature. Running either colder or hotter can adversely affect lots of things. If I were to run without a thermostat here and now in Chicago, my engine would probably never get above 100 degrees. Among other bad things, the oil would never get hot enough to drive off condensation causing corrosion unless I changed the oil weekly.
Old Dec 30, 2003 | 09:15 PM
Steve91's Avatar
Steve91
You are incorrect. The flow needs to be balanced, and it won't be without a thermostat.
Old Jan 2, 2004 | 07:11 PM
f100guy's Avatar
f100guy
even more so if you have a big 3 or 4 core radiator. the hot water coming from the motor will just flow to fast out of the radiator to make the water cool enough. you know what i am saying. the radiator will not be cooling sufficiently because it is big and the water is flowing to fast.
Old Jan 3, 2004 | 03:19 AM
'95 Splash 4.0V6
yah i know exactly what u mean... just because its flowing constantly, doesnt mean it's constantly cool. Just brain storming too much over here...
Connecticut Calvin
Aug 11, 2016 04:30 PM
Plain Jane
Nov 15, 2015 08:54 PM
LARIAT 85
58
Apr 13, 2013 12:45 PM
alexchavel
Jan 17, 2008 08:42 AM
53fatfndr
53
Nov 17, 2007 07:04 PM
