Pedal loose?
Old Jun 1, 2022 | 10:40 PM
4everFordorMerc's Avatar
4everFordorMerc
Pedal loose?
Looking for someone to verify that their gas pedal is not loose like mine. I can feel bumps under my foot in my pedal. I looked today, and the bottom connector on the pedal let’s it wiggle about half to quarter inch.
The bottom bolt attaching the pedal has play in it allowing the pedal to move before engaging.
Normal?
Old Jun 2, 2022 | 07:21 AM
KeystoneF350's Avatar
KeystoneF350
Why not tighten the bolt to remove the play?
Old Jun 2, 2022 | 09:57 AM
4everFordorMerc
I want to know that it’s not supposed to have a little give for any reason. I’ve never really messed with new gas pedals in vehicles.
Old Jun 2, 2022 | 01:21 PM
T. Banning's Avatar
T. Banning
Do you have adjustable pedals?
Old Jun 2, 2022 | 02:17 PM
KeystoneF350
I went out and checked my 2022 F350, and it doesn't have any play in the pedal. When I push down with my hand nothing moves until I overcome the spring tension and the pedal begins to depress. Not sure if it makes any difference, but mine has adjustable pedals.
Old Jun 2, 2022 | 07:30 PM
4everFordorMerc
It does have adjustable pedals. It seems like only the bottom slide mount has play in it. The top one does not. I tried posting a short video, but have no idea how to, or if you can.
I moved the pedals all the way forward, towards the drivers seat, and the play is gone as it’s pushed up tight to the stop on the bracket. I’ll see if this helps and I guess confirms the slide mounts on the bracket are loose.
dkalt
Apr 16, 2020 12:33 PM
systems
2015 - 2020 F150
Apr 12, 2019 09:35 AM
n20
Mar 29, 2010 02:34 PM
chappys4life
Oct 28, 2009 04:37 PM
