Help!
Old May 28, 2022 | 06:03 PM
Buckeye71's Avatar
Buckeye71
Help!
I drain my fuel water separator regularly usually about once a month or so..well today I did it and this is what I have in the jar
2022 f350 6.7 11k miles...haven't changed the fuel filters yet can anyone tell me what's up?
Old May 28, 2022 | 07:41 PM
jcb206's Avatar
jcb206
I am certainly no expert but doesn’t water sink to the bottom?
Maybe it biodiesel?
Old May 28, 2022 | 07:52 PM
smikesF350's Avatar
smikesF350
If you have been doing the fuel water separator drain on a regular basis and this is the first time you have had the result in your picture, then I would have to guess you got a bad load of fuel at your last fill up. To me that's a lot of water. If you have not notice and issues with your engine, then the filter and separator are doing their job. That said, I would have the fuel filters changed out. Even though I have never got any water in my samplings, I still had my fuel filters changed twice now. First at about 8600 miles and again at 30k miles. There are many who may say I am wasting money, but I see it as prudent preventative maintenance. Oh, check your fuel cap, especially if you frequent car wash places.
Old May 28, 2022 | 08:00 PM
rcinlaveen's Avatar
rcinlaveen
I have mine changed every 15k miles, or every third oil change.
Old May 28, 2022 | 08:01 PM
smikesF350's Avatar
smikesF350
Good catch. Maybe it's the new "light" water cuz they left out something to reduce the cost of manufacturing ....
Old May 28, 2022 | 08:03 PM
Buckeye71's Avatar
Buckeye71
I always drain it prolly close to once a month maybe a little longer and have never had anything in it. I do run a fuel additive since new hot shots edt maybe it did its job and helped separate it. I will run a fresh tank or 2 through and change the filters. I did notice it was a little sluggish but since than it has went back to normal
Old May 28, 2022 | 09:00 PM
hondomurph's Avatar
hondomurph
Looks a little like this sample from diesel direct .
Old May 28, 2022 | 10:28 PM
morehouse7's Avatar
morehouse7
You got some bad fuel or a leak. That water looks rusty as if churned up from a steel tank though. Keep checking and changing, good catch!!
Old May 29, 2022 | 06:06 AM
senix's Avatar
senix
change the filtes asap. Too me it looks like gas.
After you change the filters, Do a prime and before starting, drain the separator again,
If it looks the same, drop and clean the tank. I think it is gas.
Old May 29, 2022 | 11:55 AM
4wd6.7L's Avatar
4wd6.7L
I don't think gasoline in diesel seperates in that same way. It mixes with diesel fairly well. To me it looks like dirty water.
Old May 29, 2022 | 05:24 PM
Buckeye71's Avatar
Buckeye71
I have drained a few times now and it seems to be clearing up only thing I can think is I got some bad fuel somewhere
Old Jul 9, 2022 | 06:11 PM
Dave_n_florida's Avatar
Dave_n_florida
2nd Gear
Ford reprogramed my fuel pump now I can't change my filter.
Always checked my fuel water separator every month. Ford reprogrammed on a recall two weeks ago. Time to change my fuel water separator filter and when I opened the valve it would not stop dumping fuel. Used to dump out about a gallon. Today it dumped out 5 and still pouring out. No water in fuel but I've never filled up a 5 gal bucket before..... Any ideas?
Old Jul 9, 2022 | 06:22 PM
4wd6.7L's Avatar
4wd6.7L
What year truck? What was the recall? I haven't seen any fuel pump recalls.
Old Jul 9, 2022 | 06:56 PM
senix's Avatar
senix
open the valve and let it run from 15 to 20 seconds and close it. Then look at your sample. If clean you are done.
As for changing the filter, park the truck uphill and less than 1/4 tank and then change the filer. That should help so it does not keep draining
Old Jul 12, 2022 | 09:15 AM
Dave_n_florida
2nd Gear
2019 f250 super duty. Fuel pump recall I think for 2017-2020 but it's just a reprogram for a thump noise sounding.
