Excursion Cargo Door/Trunk Door Check Help
Old May 28, 2022 | 09:08 AM
JSchaa's Avatar
JSchaa
5th Gear
My 2000 Ford Excursion has a problem with the door checks on the rear cargo doors. One of them makes a terrible noise when opening. I have tried to lube it and clean it to no avail. So I figured I would replace. I spent too many hours on the google machine with no result. Stopped by Napa and they don't know what that part is either. Anyone know what this part is called?
TYIA
Old May 28, 2022 | 10:16 PM
WE3ZS's Avatar
WE3ZS
“Door checks”? Maybe a picture or better description will get you the help that you seek.
Old May 29, 2022 | 05:28 AM
solyoung's Avatar
solyoung
Do you mean the gas charged struts that hold up the top door? Or the hinges (on any of the doors)?
Old May 29, 2022 | 10:09 PM
JSchaa's Avatar
JSchaa
5th Gear
Door check is what Napa called it. I didn't want to sound like a noob so I just went with it.
Old May 30, 2022 | 09:10 AM
DB03V10's Avatar
DB03V10
4wd Low
WD-40 Dry Lube
JSchaa
I know you said that you lubed them but I had the same issue in my 03. Mine were squealing like a stuck pig, so I removed them and cleaned them with parts cleaner and a firm bristle brush. If you don’t have parts cleaner brake cleaner should do the trick. After that I lubed them with WD-40 Dry Lube reinstalled them and now I have zero squealing. I lube them every few months. Hope that helps.
Works great and doesn’t collect dust.
Old May 30, 2022 | 09:11 AM
bwguardian's Avatar
bwguardian
I've just added a little lube to them the couple times they've needed it in the past 20 years. Looking at your picture though, it appears that top bolt on the jamb is backing out, which may be the issue...
Old May 30, 2022 | 03:02 PM
JSchaa's Avatar
JSchaa
5th Gear
Originally Posted by DB03V10
JSchaa
thanks I will give it a try. I used some form of silicone spray before but never took them out and cleaned them.
Old May 30, 2022 | 03:03 PM
JSchaa's Avatar
JSchaa
5th Gear
Oh, I will check that.. thanks
JSchaa's Avatar
JSchaa
5th Gear
Old May 31, 2022 | 07:46 AM
WE3ZS's Avatar
WE3ZS
I’ve had mine disconnected for years,I like having the doors open all the way vs being,imited to straight back.
Old May 31, 2022 | 11:10 AM
Vinny G-the EX man's Avatar
Vinny G-the EX man
I agree with Tom, only I have the driver’s side hook up and the passenger side open Easier access to the back and the wind doesn’t blow the driver’s side into on coming traffic
Blacktop_one
Nov 4, 2020 10:38 AM
Olafs 7.3 ex
Jun 3, 2016 06:11 PM
Bsmith153
Nov 26, 2014 10:16 PM
Chris00
May 15, 2003 02:58 PM
