Need Alt wiring help. 89 460 efi.
Old 05-26-2022, 10:14 AM
Trav3lingman's Avatar
Trav3lingman
Trav3lingman is offline
1st Gear
So I recently inherited a 1989 e-350 class C. 460 EFI. Battery wasn't charging so I threw on a new alternator. No power still.Looked through the forums and saw a number of threads on the subject. Looked at the wiring diagrams etc. Using volt meter I checked for power at the black wires and got power with key off. I also have power on the two wire plug with engine in run position. I noticed some of the 2g alts have three wire plugs. Mine is a two wire but the Alt is a fresh reman. Some of the diagrams indicate I need three wires with the 3rd running to the white alternator wire? I'm at my wits end at this point. Electrical is barely in my wheelhouse at all.
Old 05-26-2022, 04:04 PM
AuroraGirl's Avatar
AuroraGirl
AuroraGirl is online now
You should not repair that alternator to workiung conditions. lest you burn your motorhome down
Get a ford 3g or a GM CS/AD series alternator
Trav3lingman
05-28-2022 11:40 PM
56exp
11-04-2021 09:01 AM
Vamisk
11-02-2020 02:46 PM
jereli
16
06-26-2018 06:24 PM
1979_Explorer
1978 - 1996 Big Bronco
05-12-2010 03:38 AM
Quick Reply: Need Alt wiring help. 89 460 efi.
