First oil change
Old May 26, 2022 | 07:10 AM
husqvarna's Avatar
husqvarna
First oil change
Just as I did in my 2017 diesel, I’ll be doing my own oil changes in my 2022 diesel.
I want to use synthetic. What’s everyone using? Does Ford have their own synthetic?
Old May 26, 2022 | 07:40 AM
chadstickpoindexter's Avatar
chadstickpoindexter
I’m doing the same. But I did get the dealership to change it around 1400 miles and keep the standard 10W30 conventional in it (finished using up the FP Reward points). Around 5k I did it myself. I then switched over to Rotella T6 5W40 and installed the Fomoto drain valve. I am also sticking with authentic OEM Motorcraft filters. I plan to stick with a 5k mile change interval and T6 if I can continue to get it. But yes, Motorcraft also has a full synthetic.
Old Jun 16, 2025 | 06:46 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Deleted because wrong thread.
Old Jun 16, 2025 | 06:56 AM
rufushusky's Avatar
rufushusky
They have it and they are VERY proud of it...
https://newparts.com/product/motorcr...BoCP0YQAvD_BwE
Local O'Reilly's has it on stock for like $63, Insane.
FoMoCo has their own spec for diesel oils, basically Ford wants at least 1000 ppm of phosphorus in the oil.
Here is the approved list from Ford:
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
Rotella T6 and Valvoline Premium Blue are probably the two most common 5w40s and will both work just fine.
Old Jun 16, 2025 | 08:48 AM
Boostingaz's Avatar
Boostingaz
T6. If you have one, Tractor Supply pretty much always has it in stock and they will price match anyone/anything. (I've gotten them to price match eBay adds before even). I just got some with an Amazon price match so paid $89 for 4 gallons. Then with the current at the time shell rebate I got $30 mail in rebate. So $59 bucks for 4 gallons 👍.
Old Jun 16, 2025 | 09:41 AM
WXboy's Avatar
WXboy
Valvoline Premium Blue 5W40 here. $75 for 3 gallons at NAPA.
Old Jun 17, 2025 | 07:22 AM
Conner58's Avatar
Conner58
Change your own oil !
They only way you will know what you get and to know it was done right is do it yourself !
gfmk
Jun 12, 2012 05:13 PM
PEI
Oct 26, 2010 01:45 PM
mj6gte
Apr 26, 2010 07:30 PM
PSDIESEL7.3
22
Sep 8, 2007 09:01 PM
